11-16-2009, 09:25 PM | #101 |
11-16-2009, 09:33 PM | #102 |
11-16-2009, 09:39 PM | #103 |
11-16-2009, 09:57 PM | #104 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Those wheels are fawking hawt! Why can't anyone make wheels like that in a 1.9? |
11-17-2009, 06:45 AM | #105 |
Newbie Join Date: Nov 2007 Location: Your guess is as good as mine
Later today I will post some pics of this chassis with a VP dig using the VP servo mount with a HiTec 5645 servo. Here are a few crappy pics. Last edited by sangell; 11-17-2009 at 08:25 AM. |
11-17-2009, 06:54 AM | #106 | |
I believe Vanquish will be releasing a 1.9 SLW though, now I need to build a new 1.9 as an excuse to hit them up :-P | |
11-17-2009, 06:55 AM | #107 |
11-17-2009, 10:59 AM | #108 |
I spent the begininning of my morning off by deciding what servo to use for the Vanquish Hurtz dig. Since the Vanquish dig uses a lever that gives the servo a mechanical advantage I wasn't as concerned with a huge amount of power. However I did want to make sure that I could still unlock it from a bind. My biggest desire from the servo however was SPEED. I want this thing to shift quickly. So this morning I developed a list of all the servo's I felt may possibly work. I set thresholds for the values, such as speed, weight, and power. If any servo fell below that value then I took it out of contention. |
11-17-2009, 11:16 AM | #109 |
The two servos that I was deciding between were the Futaba S9070 and the Futaba S9551. Turns out that both of these servos are shallow, more than .75" shorter than a standard full size servo. This will allow trouble free mounting with the standard Vanquish Hurtz servo mount. In the end I decided to go with the S9551 for it's faster speed and greater power. The 0.5 oz of extra weight will be a comprimise to ensure that I have plenty of power and faster response. Also turns out that this is the servo that I was recommended to use by Jason at Hobbico. http://www3.towerhobbies.com/cgi-bin...&I=LXRWS8&P=ML Last edited by Harley; 11-17-2009 at 12:01 PM. |
11-17-2009, 05:33 PM | #110 |
Good idea josh, IIRC those are servos normally used for planes? I am running one in one of my scalers |
11-17-2009, 05:37 PM | #111 |
11-17-2009, 08:27 PM | #112 |
Anyone want to take a guess? |
11-17-2009, 08:32 PM | #113 |
11-17-2009, 08:35 PM | #114 |
11-17-2009, 08:36 PM | #115 |
Pebble Pounder Join Date: Jun 2007 Location: in rc crawler land
um a transmission plate? do I win
11-17-2009, 08:51 PM | #116 | |
No, skid plate but thats not the significance. Hint: The material will not be Delrin.......nor will it be opaque. | |
11-17-2009, 09:00 PM | #117 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
11-17-2009, 09:25 PM | #118 |
| Skid design is the same that has always been on the Hybrid. Quite a bit different than the SWX and the original Hybrid had two grooves down the skid.
11-17-2009, 09:28 PM | #119 |
Downloading pictures off the camera now. I have about 1/3 of the skid finished.....
11-17-2009, 09:32 PM | #120 |
Man, you guys are slow! |
