11-17-2009, 06:47 PM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: westfeild IN
| i need some input on my build?? this is my first crawler i have been reading and i am trying to plan out my ax10 build. i want to get some input from you guys. i am not building it for comps just playin around the house and on the trail when i need a break in the jeep or the jeep breaks! new ax10 kit -tq4 2.4 with toggle mod for rear steer -Goat 2S Crawler BL System: 18.5, 5 amp BEC -Vanquish Hurtz Shifter 3 Position Dig -MIP CVD™ Front and Rear Set for Axial AX10 Scorpion (4 each) #08100 -TCS Delrin Battery Plates with strap slot for Axial AX-10 Scorpion -3Racing Upper Link Mount for AX10 Scorpion #3RAC-AX1031 -axil rear steer kit -Hot Racing Green Driveshaft Ring Retainers -CHARGER?? http://www.hobbypartz.com/thac6smbachw.html -batteries???? here im lost. i want as long of a run time as i can and lots of power. i want lipo, i just have no idea what i need? i will be running the lipo/lipos in my ax10 and the scale scx tr i want so i dont want a split pack lipo. i was also looking at this split pack for over the axle but i dont know about the runtimes/power, (TCS Crawlers 7 cell Split Battery Pack for AX10 Scorpion - 8.4 volt - Tamiya Connector) https://www.tcscrawlers.com/TCS-Crawlers-7-cell-Split-Battery-Pack-for-AX10-Scorpion-8.4-volt-Tamiya-Connector-p-16948.html what lipo do you guys recommend?? -servo? what do you guys recommend for the front and rear steer. so four Qs? -do you see anything im missing? -charger worth a darn for 7cells and lipos? -what batteries? -what servos? Last edited by tj on 37s; 11-17-2009 at 06:51 PM. |
11-17-2009, 07:03 PM | #2 |
Quarry Creeper Join Date: Mar 2008 Location: Casper
If your gonna be buying a few things from TCS, Get 2, 4 link servo mounts and 4 link it front and rear. OR go The Jetboat BTA set up for the front so that you can run a 2 cell lipo. CKRC HAS a good deal on there Lipos. Are you doing MIP Center CVDs? If so you dont need the driveshaft rings. Hpw do you plan to use the Dig ? What channel do you plan to use for Dig?? For servos on my rig with rear steer I just used a pair Of HiTech 645 s. |
11-17-2009, 10:51 PM | #3 |
Pebble Pounder Join Date: Oct 2005 Location: Rocklin / Ukiah, CA
It looks like you are off to a good start. For batteries, I am running 3s 1500mah 25c lipos. These are the ones I got. http://cgi.ebay.com/2x-25c-1500mAh-11-1v-11-1-Volt-LiPo-RC-AKKU-Battery_W0QQitemZ160377606476QQcmdZViewItemQQptZRa dio_Control_Parts_Accessories?hash=item255740114cis One battery honestly lasts me over an hour. I've been using these for a few months and they work great. This is the charger I got and it also works awesome for these lipos. http://cgi.ebay.com/iMAX-B6-Lipo-NiMH-battery-Balance-Charger-B6AC-Adapter_W0QQitemZ270440363679QQcmdZViewItemQQptZLH _DefaultDomain_0?hash=item3ef780769f The servo I run is the Hitec 7955TG. I think RPPHobbies.com has them on sale right now too. Hope this helps. |
11-18-2009, 11:58 AM | #4 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
Cheapbatterypacks.com for batteries, at least for nimh stuff, you can order them any way you want, they make them exactly how you want them, high quality stuff, quick shipping. I got two 7-cell 1500mah elite packs for $42 and they run very well, I'm able to get about 45-55 minutes out of them. For servos I'm going with hitech 7950tg. Pricey but lots of power and rated for 7.4v take a look at the onyx chargers from duratrax too, they're not too expensive but so far I've had good results |
11-18-2009, 12:54 PM | #5 |
Rock Stacker Join Date: Oct 2009 Location: YORK
why dig and 4ws?
11-18-2009, 12:58 PM | #6 |
Quarry Creeper Join Date: Oct 2008 Location: Southwest VA
I made a lexan plate and zip tied it to my front links. I then used a 2 cell lipo that would fit between the front servo and tranny. It was a 1500mAh that I could get about 45mins of run time out of with my Goat 21.5 system.
11-18-2009, 04:41 PM | #7 | |
so your saying get 2 of these? https://www.tcscrawlers.com/3Racing-...1-p-17359.html or these? https://www.tcscrawlers.com/On-Sale-...g-p-17282.html i would like the center cvds for a dig setup i dont see them on RCP or TCS? i plan to use the front/top switch for the dig. [QUOTE=the02stangman;2111285]It looks like you are off to a good start. For batteries, I am running 3s 1500mah 25c lipos. These are the ones I got. http://cgi.ebay.com/2x-25c-1500mAh-11-1v-11-1-Volt-LiPo-RC-AKKU-Battery_W0QQitemZ160377606476QQcmdZViewItemQQptZRa dio_Control_Parts_Accessories?hash=item255740114cis One battery honestly lasts me over an hour. I've been using these for a few months and they work great. QUOTE] so is it just two batts or do you use them both at the same time? and why do they have two plugs? is 11.1v to much for the goat setup? b/c i think rear steer would be badass and i put a 3speed StaK in my tj this summer and doing front digs is fun as hell haha thanks guys! | |
11-18-2009, 05:02 PM | #8 |
also will i need a CCBEC with all the servos i want to run? https://www.tcscrawlers.com/Castle-C...r-p-16518.html |
11-18-2009, 05:37 PM | #9 | |
No need for shorter top links. You can use the existing top links. Just add a rod end to the links and attach them to the bracket. Quote:
Here is the one for the front, the servo and the links mount to it https://www.tcscrawlers.com/TCS-Blac...g-p-17531.html Novak came out with a Goat system a while back that could handle 3-cell lipos. I have an older one that is rated for only a 2-cell. Just make sure which ESC you have. Last edited by awd199; 11-18-2009 at 05:39 PM. Reason: Add content | |
11-18-2009, 06:24 PM | #10 |
[QUOTE=awd199;2112604]No need for shorter top links. You can use the existing top links. Just add a rod end to the links and attach them to the bracket. Here is the one for the front, the servo and the links mount to it https://www.tcscrawlers.com/TCS-Blac...g-p-17531.html on there site it shoe the 2S alv. now and the 3s comming soon? |
11-19-2009, 03:16 PM | #11 | |
11-19-2009, 03:35 PM | #12 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
id stick with dog bones, or the felsenfast CVDs ONLY. all that other shit breaks. learn from me. i broke em and stuck the dog bones back in. i snapped an axel case in a bind. the dog bone wasnt even bent tcs, stnc or bender customes 4 link plates omit the 2 split pac battery plates and get ONE servo/battery plate and go with lipos (axial Vanquish or STNC i think the goat sux. id go castle sidewinder, or mamba, tekin fxr or fxr pro. save the money and dont buy a combo, and sink that cash into a warrior or Holmes Hobby professional had wound brushed motor and CC 10AMP BEC. and i assume you are aware that rear steer is not comp legal you dont have a Losi, so nooo need for Bl, and the Goat is only 2s lipo. and it will still glitch w/o a external BEC. the dig you chose is the best out Last edited by BEELZEBOB; 11-19-2009 at 03:37 PM. |
11-19-2009, 09:59 PM | #13 |
Newbie Join Date: Sep 2009 Location: schnecksville
| agreed
i totally argree with you guys on the goat i own one as well 2s one and its not the greatest , but it will work for now unless you find someone willing to buy it , i am buying a castle as well with a bec with computer link , and using my bl goat for a scaler. another purchase i would suggest is the upgrade your axial trans gears withthe integy hd gear set for like ($30) it makes this trans bullet proof.
11-20-2009, 12:38 AM | #14 |
Rock Stacker Join Date: May 2009 Location: grand junction
