02-26-2010, 09:32 PM | #101 |
Anybody else have an issue dropping the locker into the case? Seems the unit is about .030" longer than the cutouts in my housings.
02-26-2010, 09:51 PM | #102 |
RCC Addict Join Date: Jul 2008 Location: San Diego
What holes do you have to open up?
02-26-2010, 09:58 PM | #103 |
02-27-2010, 04:50 AM | #104 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
02-27-2010, 05:39 AM | #105 |
Quarry Creeper Join Date: Oct 2009 Location: Indianapolis, IN
02-27-2010, 07:37 AM | #106 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
your not using those little gasket deals on the ring gear are you?
02-27-2010, 08:28 AM | #107 |
Nope, no gasket. Tried two different rings, new bearings, etc., if I take the bearing on the ring off the ring hits the housing but with the other bearing off it drops right in. SDS was quick to answer my PM about it last night and is supposed to get some numbers to me here soon. I'm sure it's gonna be taken care of but I wanna use these in a comp tommorrow if I can. Just got off the phone with SDS, great customer service. The cutouts in my housing seem to be tighter than most, he gave me a couple different ways to make this work. Last edited by indiana mudcat; 02-27-2010 at 01:10 PM. |
02-27-2010, 03:43 PM | #108 | ||
Rock Crawler Join Date: Dec 2008 Location: dallas
As for steering, a stock axial cvd will turn 46* or so. after that its almost certain failure. With the 300's u get piece of mind that the pin is approx. 1.7times the size of the Axial pin as well it is able to turn 4* or more farther. Add to that a shaft made of far superior material. Hope everyone enjoys there shafts. | ||
02-27-2010, 08:41 PM | #109 |
Thanks for taking the time out of your day to help me out SDS, I got em in and got a test run in around the house. Pure Beef, I didn't do anything stupid but did drive through a couple binds that woulda made Axial CVD's scream for mercy. I was giggling like a little girl with the lower gear I feel safe to run now doing wheelies and backflips , can't wait to comp in the morning. Also these take a huge amount of slop out of the truck, there's still a tiny bit of "BTA" wobble but not near as much as before. There's zero slop in the knuckle unlike the Axial dogbone or CVD, nice and tight. Locker slop is completly gone also. Great product. |
02-27-2010, 11:37 PM | #110 |
a little progress report: my set screw idea didn't work. first course one side worked its way out. the next course the other came out. i put some red locktite on them and they held for the rest of the night. and no breaks |
02-28-2010, 08:47 AM | #111 |
thanks for the update, I would have thought that the set screw idea would have nailed it.(dang plastic)
02-28-2010, 08:53 AM | #112 |
i got to thinking about it and maybe if i had taken the bevel off of the set screw it might hold better. with the bevel i think it was only catching a tread or two. i tried to re tighten before i did the locktite and it just felt stripped. another though i had was to go all the way through the alum knuckle so i know there is plenty of thread for the screw to catch onto. i might still do this, just need to pick up a tap for 3mm thread |
03-01-2010, 10:27 PM | #113 |
My bearings both walked by the end of sundays comp also, I put the loctite outside the bearing and think i should have loctited the bearings to the shafts. I did finally make it through a comp without breaking a CVD though and I beat the snot out of em. Last course was a rock race and I used everything the 18.5 had, took two three foot falls, rammed rocks full throttle, drove through binds, etc. and the 300's just took it. I did find the next weak link on my truck though, with BTA I've never had a servo horn issue before. On the fourth course I got the steering bound up and twisted my aluminium horn 45 degrees, cracked it down the center and ripped the screw out of it. Super 300's and 8711 FTW I did finish 3 of 5 courses would have finished 4, but clipped the last gate and pointed out on one cause i was running short on time and pinned it and hoped. Last edited by indiana mudcat; 03-01-2010 at 10:33 PM. |
03-01-2010, 10:54 PM | #114 |
Newbie Join Date: Jan 2010 Location: montrose
What are super 300s? sorry |
03-01-2010, 11:04 PM | #115 |
03-01-2010, 11:32 PM | #116 |
O cool sounds sweet to me!
03-02-2010, 04:55 AM | #117 |
| yep. i just removed my axles and put a dollop on the axle where the bearing rides. put the bearing over the axle and work it under the bearing.
03-10-2010, 12:03 AM | #118 |
RCC Addict Join Date: Jul 2009 Location: AT THE DRAGON'S LAIR
Red lock-tite is not keeping mine in, I just don't want to freeze the inside of the bearing. Other than that they did awsome on their first comp, even when the bearings walked. |
03-11-2010, 05:46 PM | #119 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
What exactly is the issue with the bearings walking? Which bearing, etc? |
03-11-2010, 05:52 PM | #120 | ||
there is no flange machined on the axles so red locktite is required so they dont work their way out of the axle housing and up against the CV joint | ||
