01-04-2010, 03:26 PM | #1 |
Quarry Creeper Join Date: Nov 2009 Location: East Greenville
| Show me how you mount your electronics
Im looking to see how you guys custom mounted your electronics on the inside of the chassis so i can get an idea, also would hobbytown carry the 12 guage wire for the battery,motor,esc and etc.?
01-04-2010, 03:42 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
01-04-2010, 03:55 PM | #3 |
Quarry Creeper Join Date: Jun 2009 Location: Tri-Cities
This is how i have Mine all setup, a little messy, but it gets the job done |
01-04-2010, 04:11 PM | #4 |
Rock Crawler Join Date: Feb 2007 Location: wahiawa
what kind of chassis are you using? all chassis have different ways for mounting electronics!
01-04-2010, 04:22 PM | #5 |
im using stock chasis
01-04-2010, 04:23 PM | #6 |
sheedy has a gatekeeper special ed. i mean agent |
01-04-2010, 05:40 PM | #7 |
Here's mine. I think it's pretty clean. 12 gage wire is way crazy overkill for a crawler, but yes, most HTUSA's will have it. I'm running 18 gage from the esc to the motor. |
01-04-2010, 05:43 PM | #8 |
Sweet, thanks manning, did you just use normal houshold wire not the flexible stuff, and is ur tranny mirord due to the dig?
01-04-2010, 07:01 PM | #9 |
Pebble Pounder Join Date: Oct 2009 Location: Spanish Fork
my receiver and torquemaster br-xl are mounted on little pieces of lexan.. with Velcro.. oh and the lipo mounts on the front links where the velco is... The wire job is just temporary cause I should be getting a puller tomorrow Last edited by 311WJ; 01-04-2010 at 07:07 PM. |
01-04-2010, 07:06 PM | #10 |
Rock Crawler Join Date: May 2009 Location: Medford, Oregon
01-04-2010, 07:33 PM | #11 | |
http://www.tqracing.com/ Yes, the trans is flipped. I had to think about that for a bit, it's been so long since the first dig was installed..... | |
01-04-2010, 08:07 PM | #12 |
Rock Stacker Join Date: Dec 2009 Location: denver
01-04-2010, 09:21 PM | #13 |
Rock Crawler Join Date: Jul 2009 Location: waterville
i cant give any pics at the moment, but heres what i did. getting all weight low as possible. i made two plates. mounted my receiver and esc on the rear axle. using the servo plate mount holes on the outsides closest to the tires is where i mounted them. i havent seen anyone run them like this for except moa's. for the front i built my own plate close to the big one that you can offset your servo. but mine stops in the center where the links bolt to. then i put another bent plate coming from the first one angled down laying down on the axle. i have enough room fora 3cell lipo or a 2/3a 7 cell. thats the lowest i could get everything. when i get some more time. ill takes some pics
01-06-2010, 01:39 AM | #14 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Use 12 or 14ga tekin/deans/ or other good silicone insulated oxygen free copper wire. Don't use household stuff though. Its solid core and not flexible enough. Your esc has 14ga, so you might as well use the same. Here's a couple pics of my vanquish incision chassis ax10 electronics |
01-06-2010, 05:34 AM | #15 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
| neet cleen and tight GSRCC Drail |
01-31-2010, 12:32 AM | #16 |
Newbie Join Date: Jul 2009 Location: North Idaho
Rx mounted on plate on front links, antenna plate glued to Rx. ESC is mounted to custom plate that mounts to the underside of the top battery plate, it also serves as a wire guide. Slightly modded servo mount for dna dig. In the process of front axle battery setup. I think i will still keep the top battery plate for frame rigidity and its not too heavy so very minor effect on cog. |
01-31-2010, 01:26 PM | #17 |
Rock Stacker Join Date: Jul 2006 Location: Seattle
01-31-2010, 04:24 PM | #18 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
01-31-2010, 05:53 PM | #19 |
Newbie Join Date: Oct 2009 Location: chickamauga
I mounted my receiver on the front upper link plate and the esc on the rear upper link plate. Probably not the best but it works for me.
02-01-2010, 09:02 PM | #20 |
Rock Stacker Join Date: Aug 2009 Location: Verwood, dorset, uk
It's a custom torsion chassis, but I ran the electronics pretty similar on the stock chassis. Only difference is the reciever goes on a plate mounted the the front upper links. |
