01-07-2010, 09:17 PM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: columbus
| anyone built an Eclipse with a Vanquish dig
I am tring to find out if I can use my Vanquish dig with the hurtz shifter in a TCS Eclipse chassis? Any help would be great. Thanks. Bob
01-07-2010, 10:35 PM | #2 |
I doubt you'd be able to get it to fit with the servo anywhere in and near factory position. Maybe you could have Gunnar make you a vertical micro servo mount, and it MIGHT fit. Edit: Scratch that. The servo is probably ok where VP puts it, but the dig probably won't fit cause the left rear upper will be in the way. Evem if you make a custom skid that moves the trans forward, the spur will stick wayyyy out of the front window area Creepy built one with an Eritex and that fir, but it's tiny. Plus you'll probably have to mount the esc and rx way up high or on the back axle. Last edited by TSK; 01-07-2010 at 10:39 PM. |
01-26-2010, 08:22 PM | #3 |
Pebble Pounder Join Date: Dec 2009 Location: Living on the edge!
| Vanquish dig/standard servo/eclipse
Yes, I have an Eclipse chassis w/ Vanquish HSDig and a standard servo. It fits good and the servo gives you a place to mount esc or rx. |
01-26-2010, 08:26 PM | #4 |
Well there ya go. It doest fit |
01-26-2010, 08:48 PM | #5 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
I've been curious about this as well...pics please motur! Scorp, did gunnar hook you up with that 10T? I've got one that I'm installing with my winter my overhaul and I'd like to get your thoughts |
01-26-2010, 10:30 PM | #6 |
| pics |
01-26-2010, 10:36 PM | #7 |
Holy hell Should be no issue with the mini mount then. Cleared everything below as well...motor, side tubes etc? |
01-27-2010, 12:17 AM | #8 |
Everything looks like it's in thre nice and tidy. Micro servo would be great cause then you could probably sandwich the rx next to it.
01-27-2010, 12:26 AM | #9 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Yea, I'd vote for a micro as well, then all the electronics could be moved lower. I'll keep my mouth shut about the LCC in the background.
01-27-2010, 12:42 AM | #10 |
