01-11-2010, 09:56 PM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: west sacramento
| torque twist...
torque twist. some simple ways to...lessen it. thanks fellas |
01-11-2010, 10:13 PM | #2 |
Newbie Join Date: Oct 2009 Location: HighTop
CKRC claims if you move the limiters internal on the shocks that will help. I did that on my stock shocks and it did help but I did a few other things at the same time so I don't know how much it helped. Also, when I lowered mine it seemed to help alot.
01-11-2010, 10:23 PM | #3 |
The best way to lessen it is..... ...the search button! Of course its not the easiest way...but there are literally hundreds of threads on this very subject. |
01-11-2010, 10:31 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
here are some ways to lessen it 1. Limiters (but articulation will be bad, and flex is the key to any crawler) 2. stiffer shocks 3. add front/rear weight, wherever the twist is. 4 internal shocks 5. some more oil should kinda help |
01-11-2010, 10:34 PM | #5 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
01-11-2010, 10:36 PM | #6 |
01-11-2010, 10:39 PM | #7 |
| I've been through all that, but there is a better way. I can make my left front tire lift instead of my right front if I want it to...and its not using any of that listed above...in fact, my rigs have none of that listed above...
01-11-2010, 10:41 PM | #8 |
If you do a search on torque rwist you'll find just about everything you're looking for, and then some. You'll find there is not one thing that curse this, but a lot of things used together to limit torque twist and allow you to use it to your advantage. The first step in your quest will likely be going to 4-Link and different shocks. |
01-11-2010, 10:56 PM | #9 |
01-11-2010, 11:39 PM | #10 |
RCC Addict Join Date: Jan 2007 Location: San Jose
i have learned link setup up makes a big difference instead of changing the rr side which masks the issue.
01-11-2010, 11:46 PM | #11 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
4 link and sear mirror the tranny!!!! and search search search and when you think your done search some more
