03-08-2010, 03:38 PM | #41 |
Rock Stacker Join Date: Nov 2009 Location: NM
03-09-2010, 08:37 PM | #42 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
I really like this mod. Good work!
03-10-2010, 12:14 AM | #43 |
Newbie Join Date: Nov 2009 Location: Trabuco Canyon
Sorry for being a noob, but whats the big deal about this. Whats the benefit of having your links inside as opposed to outside? I was considering doing this but its a lot of work. Is it worth it? sorry for hijacking.
03-10-2010, 12:23 AM | #44 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
| It's so your link ends don't hang up when the side of the chassis slides along the rocks. Basically, the smoother you can get the underside (and sides) of the chassis, the better it will work, and not catch on any pointed rocks, etc. If you look at most comp chassis', the links will be inside, and button or countersunk screws will be used to clean up the lower sides of the chassis.
03-10-2010, 04:27 AM | #45 | |
Quarry Creeper Join Date: Feb 2005 Location: Atlanta
03-10-2010, 07:45 AM | #46 |
03-10-2010, 01:16 PM | #47 |
Newbie Join Date: Mar 2010 Location: lebanon
dose it give u more flex iv put a tube chassis on mine new shocks droop setup was wondering how to get more flex will this mod help with that
03-11-2010, 09:01 AM | #48 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
No, it doesn't give more flex (it doesn't hurt either). The thing that limits flex is the link ends. The link ends can only twist so far on the balls. The ends on each lower link must be lined up with each other to get max flex. If they're not, one link will bind in one direction and limit flex. I found this on mine, wondering why one shock was not fully compressing when crawling. In the process I also found that there needs to be a champher on the outboard side of the cutouts in the skid plate to make clearance for the link ends. If not done the links rub heavily there at full flex, it forced some of my links to come off the balls. I also put the flange on the ball to the inside to help keep them on if it gets a bump. So line up yer link ends and champher the cutout, it'll flex nice and smooth and just as much as stock. Cheers. Edit: Ever wonder why Axial put those limiters on the shocks? Obviously because the links don't allow that much motion. Remove the limiters, it will bind. Do you really want that much flex anyhow? Sometimes, 70* is too much, the truck develops a mind of it's own. Last edited by Terranaut; 03-11-2010 at 09:08 AM. |
12-08-2010, 06:17 AM | #49 |
Rock Stacker Join Date: Nov 2010 Location: nunya
| better screws
i done the same thing except i didn't use the bulky headed screws i used traxxas cap screws which have a small head and are the perfect length they are fine thread but they are just small enough to thread in the holes i have had these on my ax10 rtc and used them when i got an integy chassis and the have proven to be plenty strong.. plus i put my links in the outer holes and the screws stick out of the plate like dowel pins on a 1:1 transmission and motor so that really helps the strength. the best thing is you can still use these if you want to put them through your links with a nut.u just need a longer screw from traxxas these are what i used-http://www3.towerhobbies.com/cgi-bin...&I=LXZT78&P=OW these are some longer- http://www3.towerhobbies.com/cgi-bin...&I=LXZT78&P=OW longer-http://www3.towerhobbies.com/cgi-bin...&I=LXHFN0&P=OW notice the heads have smoother edges so they wouldn't hang up as much...that's part of the reason for the inboard linkhttp://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHFN0&P=OWs |
12-08-2010, 11:37 PM | #50 | |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
12-09-2010, 04:53 AM | #51 |
12-09-2010, 06:13 AM | #52 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
instead of using those 4 screws into the plastic, run them straight through the chassis plates and use 2 sets of nuts and bolts to tie them into the chassis plates .........bob .... |
12-18-2010, 12:00 AM | #53 |
Rock Crawler Join Date: Aug 2010 Location: Socal
I ran my stock axial skid like that also but instead of using course screws I used 3mm screws that went through the chassis skid and link with a nylock nut. Over time the course screws work their way loose in the plastic.
03-16-2011, 07:09 PM | #54 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
Can you just use the Skid plate from the SCX10 on the stock AX10 chassis???
03-26-2011, 10:11 AM | #55 |
Newbie Join Date: Mar 2011 Location: dryden
this is how i saw to do it and i did it this way on my ax10. i also have the droop setup. |
03-26-2011, 11:46 AM | #56 |
03-27-2011, 09:38 AM | #57 |
oh ya i got internal springs. wouldnt be as good without them.
03-27-2011, 06:04 PM | #58 |
Newbie Join Date: Jan 2011 Location: PORTUGAL
