02-25-2010, 07:24 AM | #21 |
Rock Stacker Join Date: Feb 2010 Location: winnipeg
the shocks look WAAAAYYYY better now!!! |
02-25-2010, 06:45 PM | #22 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
02-25-2010, 07:49 PM | #23 | |
Pebble Pounder Join Date: Aug 2006 Location: Raleigh NC
Zack | |
02-25-2010, 07:52 PM | #24 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
Hay man, that looks good! looks more like a buggy crawler, I was kinda tired of seeing the same things....honchos....bronco's, jeeps. ect... good to see a fresh Idea once in a while, keep up the good work.
02-25-2010, 09:07 PM | #25 |
Newbie Join Date: Jan 2009 Location: townsend
loven the tuber. |
03-21-2010, 10:35 PM | #26 |
Pebble Pounder Join Date: Mar 2010 Location: Bend
looking sweet so far! Love home builds! |
02-02-2011, 04:45 PM | #27 |
| Finally Done!
Well after graduating college, getting a job, and getting engaged, this thing is finally done! To recap, here are the specs on it, 35t HH Torquemaster 540 Axial Transmission/Vanquish DIG JunFac shafts(when they get here from Korea) Hitec 7995tg and Hitec 645mg Tekin Rebell II ESC CC BEC Liposhield Lipo Cutoff 11.1v, 2000mah 3s lipo Enough of that, on to the pictures. So there it is. I'm still thinking about skinning it with some body panels. Now I just need to finish programming the radio. After I get the junfac shafts in, I will strip everything off and paint, clean up etc... On a side note, my steering servo has plenty of power, but sometimes it does not want to turn, I have the BEC running directly to it. I can stand the rig directly on its front wheels and saw it back and forth and its fine, but on carpet etc, it sometimes does not want to turn. Also, I can operate the dig function the "long" way. Meaning I can manually control each point on the Dig. I want to set it to where one position is engaged, one is free wheel, and one is locked. Any ideas? Thanks guys. |
02-03-2011, 01:22 PM | #28 |
Your servo is struggling to fight the horrendous scrub radius that is caused by the wideners. You'll notice that as you steer the tires move front to back a ton because the steering centerline is so far away from the center of the tire's contact patch. Not only does this make life hell on your steering servo, it also multiplies the stress on the steering knuckles, C-hubs, axlehousings, and axleshafts. Moral of the story, it may look cool being so wide, but it isn't necisarily going to work better. Good work on the chassis! |
02-03-2011, 02:41 PM | #29 |
I agree on the wideners....I had to put them on there in order to have somewhat a steering radius without the tires rubbing the chassis. Since I have the servo on there, I can limit the turning radius via the transmitter. That should help on the scrub radius. I believe I also need to bump the voltage up from the BEC, its only running 5v right now. Am I correct?
