02-25-2010, 02:02 PM | #1 |
Shortening my truck??
I am looking into the rules of running the sportsman class, and it appears that I am ever so long and need a bit of a haircut. I have integy lower arms and an integy alloy upper arm. I am going to need to drop a little under a quarter of an inch off my truck. On major part of this however is that I moved my lower arms inside the chassis as suggested by another thread so moving the lower arms more inboard is not really an option. I do like how the truck is much softer with the arms inboard the chassis though.
02-25-2010, 02:31 PM | #2 |
Suck it up!
Cut or grind 1/8" off of the lower links. Or better yet, ditch the crappy Integy links and get a delrin set that will put you into spec.
02-26-2010, 07:37 AM | #3 |
What link ends are you running? The stock offset ends are longer than the straight ends. I put straights on both ends of mine and, combined with inboarded lowers, I've ended up 3/8" too short. So just using straight link ends might do it for ya?
Cheers. |
02-26-2010, 01:05 PM | #4 |
Shelf queen
You could try moving the links outward on the axle.
02-26-2010, 01:19 PM | #5 |
you can go even further inboard with the lower links if you need to. Shim under the tranny to raise it a couple mm, then shim the links in further. I have played around with that a bit until my FF-4 gets here
