Thread: Which wheels have more offset to prevent rubbing.
Old 03-03-2010, 01:16 AM   #1
Default Which wheels have more offset to prevent rubbing.
Hey guys,
I have a vanquish chassis'd AX10 and have the electronics tray up front for the servo and lipo. When i am at full lock the tires slightly rub on the servo mount.
I have rovers on proline titus wheels. What wheels can i get that sit out a bit further to prevent this rubbing? are any of the Vanquish or mahem wheels made like this? is there just a particular offset that will fix this problem?
thanks
Alex
axeten is offline   Reply With Quote
Old 03-03-2010, 02:09 AM   #2
i know there are widening kits you can buy for them, or just try adjusting your epas
liverkiller1 is offline   Reply With Quote
Old 03-03-2010, 02:40 AM   #3
Default ...
I've adjusted my EPA's but that means i dont have as much steering as i could have. So i thought i'd check before i bought new wheels
Old 03-03-2010, 12:37 PM   #4
The stock wheels are stronger, hold a bead better and have more offset. x2 for VP's or Mayhems. My tires still get in the servo and battery with 585 offsets on VP DH's, but I run 300's with a ton of steering, washers will space the VP's out farther.
indiana mudcat is offline   Reply With Quote
Old 03-03-2010, 12:37 PM   #5
If i remember correctly the proline wheels sit a bit narrower than other wheels, i think any wheel that is for the ax10 should stick out a little further.
mindless is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
