03-13-2010, 05:44 PM | #1 |
Rock Stacker Join Date: Jan 2006 Location: aberdeen
| newbie mod question
what are some good mods that dont cost anything desides batt on axle anything would help THANKS!!!!!!!!
03-13-2010, 06:05 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
Mirror the trans, vent holes in the wheels, sipe the tires and/or cut some tread out of the stock tires. There are tons of cheap mods too, make your own links, weight the wheels, it goes ON and ON and ON. every little bit helps, try one thing at a time and see what helps "you" the most. I found, if you have a small area to put a course, start collecting rocks, set up an area to crawl. Then you can figure out what works, and what dosn't.
03-13-2010, 11:51 PM | #3 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
03-14-2010, 12:06 PM | #4 |
Pebble Pounder Join Date: Oct 2009 Location: Whitmore Lake
Cut the skidplate and move your links inside the chassis, aka the skidplate mod |
