03-20-2010, 04:26 PM | #21 | |
Pebble Pounder Join Date: Jan 2009 Location: At the workbench
The 3 bare cells(in your other thread) will need to be wrapped. Last edited by PsychoCrawler; 03-20-2010 at 04:29 PM. | |
03-20-2010, 06:47 PM | #22 |
Pebble Pounder Join Date: Nov 2009 Location: Bunbury, WA
I'd be scrapping the Nimh's. Its so big and heavy. If you go to hobbycity.com you can get Turnigy 1000mAh lipos for about $9 and buy a budget lipo charger. |
03-20-2010, 09:20 PM | #23 |
Quarry Creeper Join Date: Jan 2010 Location: Gill, Taxachusetts
03-20-2010, 10:03 PM | #24 | |
I run 1300mah 30c 3s's in my comp rig and get 30-45 minutes of fairly hard driving with a 14t Puller motor. They cost about $18. | |
03-21-2010, 04:45 AM | #25 |
03-21-2010, 08:33 AM | #26 | |
Newbie Join Date: Feb 2010 Location: Calgary
cheap saddle pack One saddle will go flat on the front axle, and the other at the front of the oe battery tray. Will improve my cog dramatically. I tried all 6 cells on the front axle and it was too heavy, did a catwalk the wrong way down an incline, before rolling and stripping the servo horn. I may extend the leads between and do one saddle on each axle, haven't decided. The spot welds will just pull off, and then sand down the little pricks standing up, or you can cut the tin inbetween the cells. I removed the tin strips and sanded, my cells were bare - so they got a strip of paper around them. If you can go with lipos by all means they're a fantastical idea! If you can't yet don't be afraid to rip something apart, lots of people here can and will help you if you get stuck! | |
03-22-2010, 05:46 PM | #27 |
I guess I need to go to Lipo's. I will also need a charger w/ a balancer, Lipo cut off and.... what ? Anything else?
03-22-2010, 06:24 PM | #28 | |
I'm in Australia and the longest i have ever waited for China stuff is 2 weeks. US takes 2-3 depending on time of year | |
03-22-2010, 07:44 PM | #29 | |
0 0 Join Date: Jul 2006 Location: FT. Thomas
here's a cheap charger ive read people on here have used and like http://cgi.ebay.com/ws/eBayISAPI.dll...fvi%3D1&_rdc=1 you can either buy a lipo cutoff such as http://www3.towerhobbies.com/cgi-bin...P?I=LXPGM8&P=8 ide recommend just getting crawler specific esc with a lipo cutoff built in. if you go 3s you'll need a BEC too. it isnt mandatory with 2s. and lipo batteries i think are very cheap. for the cost of 1 good NiMH 5000 MAH battery you can get a few good 1100 lipo packs | |
03-23-2010, 05:32 AM | #30 | |
03-23-2010, 05:43 AM | #31 | |
03-23-2010, 06:16 AM | #32 |
03-23-2010, 02:54 PM | #33 |
03-23-2010, 02:56 PM | #34 |
One other thought, if you plan on getting your truck wet, don't use paper to wrap the cells. It'll fall apart and could cause a short.
03-23-2010, 06:57 PM | #35 | |
Thanks for all the advise. | |
