03-21-2010, 09:10 PM | #1 |
RCC Addict Join Date: Jan 2010 Location: Dallas
| Chassis?! or Shocks?! or Wheels?!
Alright. I got some money to spend. I need help picking what on. First I am going to get some rovers. No question. Now I gotta narrow down my priorities. Here is what I am watching. I really like the FF4 chassis. Am I stupid for ordering a chassis if I am running the stock shocks with alu upgrades and running proline plastic beedlock wheels? If I had my pick I would go chassis, then wheels, then shocks? What am I missing?
03-21-2010, 09:15 PM | #2 |
Pebble Pounder Join Date: Nov 2009 Location: Bunbury, WA
I have done all those upgrades but Chassis is definately the best by far. Tires also. I have seen many good setups with stock shocks and wheels.
03-21-2010, 09:15 PM | #3 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
ide say chassis then shocks then wheels. get the chassis and the shocks together if you can. wheels are really iffy IMO. ive had no issues running the stock wheels. while ive read of others stripping hexes. just keep the wheel nuts tight and the plastic wheels should last a long while |
03-22-2010, 08:14 AM | #4 |
| Thanks guys
Thanks guys. A new chassis is in order then!
03-22-2010, 12:04 PM | #5 |
Quarry Creeper Join Date: Aug 2009 Location: Gamecock Country
As long you have rovers(white dot) at the top you are good to go. But yes, a chassis would be next.
03-22-2010, 02:29 PM | #6 |
| Rovers are on order.
Rovers are certainly at the top. I am using hammers now and they are far better than stock but still just not cutting it.
03-22-2010, 02:57 PM | #7 | |
Nova's Ark Double Deuce foams for certain | |
03-22-2010, 03:15 PM | #8 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
id say go with the chassis and just buy softer springs for the stock shocks for time being
03-23-2010, 07:58 AM | #9 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
| I would get the rovers & foams first. They will make a huge difference over the Hammers! I've got the FF-4 chassis and it is top notch I'm still gathering parts for the build, its gonna be slow, but it'll be my comp. rig for next season so I've got a while... |
03-23-2010, 08:16 AM | #10 |
| The tires are definitely on the list
I am definitely getting tires no question about it, but I am think I am going to get a chassis while I am at it. I am now struggling with trying to order delrin or simply order stainless steel for lower links.
03-23-2010, 08:23 AM | #11 |
Pebble Pounder Join Date: Nov 2008 Location: tacoma
i run stock shocks with some tweaking they seam to work fine |
03-23-2010, 10:20 AM | #12 |
| Shocks
I am running the integy aluminum upgrade parts for the stock shocks flipped and I am either not bleeding them right or something as they simply have this odd first bit of travel that is not cool at all. Feels grainy or spotty or something. I am probably going to have to take them to a shop and have some one show me how to bleed a shock right. I know I know........ Integy sucks but I got a great deal on them! I am probably going to stick with them as I am super pumped about everything else.
03-23-2010, 01:05 PM | #13 |
integys are just garbage get yourself some losi 4in or big bores as for links get delrin less hangups and most likely cheaper and easier to work with |
03-23-2010, 01:46 PM | #14 | |
both ways I have enough leftover material to make a 2nd set The delrin slide on areas the SS did hang up on too. SS slid on areas aluminum hung up on. SS is strongest, delrin "can" break but is so cheap just make a new one! | |
03-23-2010, 02:20 PM | #15 |
| SS the cheap and easy way
I have been making my own SS links using threaded rod (all thread) and ss tubing. I use a small grade pipe cutter to cut it square and to length. This way the SS tubing is a LOT cheaper and much easier to work with.
