03-24-2010, 11:17 AM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Poway
| BTA steering kits / reviews
i'm considering a BTA steering setup. i've heard of the RPP Hobby's LD Racing BTA Kit being decent. but i've not found any actual reviews or pictures of it installed. does anyone have actual pictures or experience in using this kit? |
03-24-2010, 12:15 PM | #2 |
Rock Stacker Join Date: Feb 2009 Location: Oslo, Norway
03-24-2010, 12:57 PM | #3 |
03-24-2010, 02:33 PM | #4 |
03-24-2010, 03:14 PM | #5 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
i just installed by LD racing bta, its nice and cheap im running axial alum knucks i just grinded down the outside screw hole has plenty of clearance with the included spacers i did have to grind down the corner where the servo is at on the inside for clearance but nothing major the only thing that kinda bugs me and its that way with the other bta kits is the wheel wobble, what ive notice with mine as well is that the screws holding the tie rod in with the spacers cant be over tight or the servo with be in overdrive to push the rod it works great and its cheap |
03-24-2010, 06:37 PM | #6 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
03-24-2010, 08:18 PM | #7 |
ill have to give those i try got them on order now my setup is about the same as yours minus the vp knucks
03-24-2010, 08:39 PM | #8 |
You will really like the VP knuckles, it makes a huge difference, gets rid of the spacers and you will no longer have the shock/lower link mount to worry about because the hi-steer arm sits above all of it... |
03-24-2010, 09:03 PM | #9 |
RCC Addict Join Date: Jul 2008 Location: San Diego
I have the Axial BTA. If you want to see it I live in Mira Mesa. Matt
03-24-2010, 09:16 PM | #10 |
Rock Crawler Join Date: Jan 2010 Location: Arvada
| I'd like to see some pics of your axial bta set up. I have one that I just took off because it's giving me nothing but problems. I'm about to re do it and if you got yours set up and you're happy with it then maybe I can use yours as a reference when I do mine again.
03-24-2010, 10:04 PM | #11 |
hey with the vp knucks is there still that wheel slop/wobble?
03-24-2010, 10:12 PM | #12 |
| Can't say I have a problem with wobble or slop on mine, I am currently using stub shafts and axles because i have been blowing up CVD's, mine tire and wheels only move slightly from side to side but I thinks that is more just the tire not being 100% true, not caused by the steering.
03-25-2010, 01:15 AM | #13 |
ya im running the axial hd cvd with gunnars pins these pins have lasted longer then the stocks for sure, right now i got dh comps with a 350 offset with is not enough, but my slws with 600 should solve the front ha, ya i hope once the vp knucks get here itll solve the slop
03-25-2010, 09:30 AM | #14 | |
thanks for the info and tips everyone. | |
03-25-2010, 10:15 AM | #15 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
I just pulled the original v2 (ldrp/jetdesigns) kit off my axles for a "tuneup". After 2yrs and I don't know how many batteries and 3 servos, it showed very little wear around the holes in the tie rod, the spacers where perfect. I drilled out the holes, inserted some bushings from axial and put it all back together with a jr 8711. Ldrp took my design, cleaned it up a bit with some suggestions from me and in my opinion, now has the best bta on the market. |
03-25-2010, 10:00 PM | #16 |
Here are the pictures of the BTA. Last edited by SDheavymetal; 03-25-2010 at 10:06 PM. |
