ARTR vs RTR is there a difference inside the axles between the 2? |
pretty sure the rtr has differentials and the artr has spools |
the r2r comes with 27t motor, tx/rx and servo open front locked rear, plastic links all around and shitty tires the artr you will need to add all your own electronics, locked f/r with semi decent tires and aluminum links |
Have you looked at the RTC? http://www.axialracing.com/ftp/ax10rtc/ The green box's mean it comes with it. I got the RTR -I wish the RTC. The RTC came out after I got my RTR. RTC comes with better tires and a 55t motor. |
I have a bunch of AX stuff here, my comp rig has axles from a rtr, and I have a ATRT roller here, just wanted to know if the ARTR had better axles |
I guess only the Kit comes with the alum. locker then -er no? |
