04-17-2010, 11:28 PM | #1 |
Newbie Join Date: Mar 2010 Location: Santa CRUZ
| Witch clockable c
So I Brooke the stock c on my ax-10 and was wondering witch clockable c I should buy. I ask because I heard some clock the wrong way, thanks |
04-17-2010, 11:53 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
i like my axial ones |
04-18-2010, 12:21 AM | #3 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
I've had good luck with my Strc c's and knuckles. nice fit
04-18-2010, 06:44 AM | #4 |
RCC Addict Join Date: Oct 2008 Location: PA
04-18-2010, 07:50 AM | #5 |
04-18-2010, 11:36 AM | #6 |
The clockable part is useless, they give the option of stock caster or way to much foward caster (the same as putting them on backwards). That said I prefer the Axial ones as they can be made to be rock solid tight where most others wobble after one course of my abuse. To keep them rock solid I added 3x3mm setscrews to the empty holes, which also helped to keep the bearings seated with Super300's.
04-18-2010, 11:43 AM | #7 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
axial c's w/ vp knucks
04-18-2010, 03:40 PM | #8 |
Quarry Creeper Join Date: Apr 2009 Location: KC
04-18-2010, 05:00 PM | #9 |
RCC Addict Join Date: Jul 2008 Location: San Diego
I have the axial "C"'s and the are great! x4
04-18-2010, 05:31 PM | #10 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Axial clockable C's: UNCLOCKED: CLOCKED: |
04-18-2010, 07:00 PM | #11 |
Thank you all for the information I will be going witch the axial c's |
04-20-2010, 11:02 PM | #12 |
Pebble Pounder Join Date: Dec 2007 Location: Arvada
04-20-2010, 11:39 PM | #13 |
11-25-2010, 10:38 PM | #14 |
Quarry Creeper Join Date: Oct 2010 Location: SLc,UT
Who else makes a quality clockable c? Or is there one out there that you can mod and make it clockable?
11-26-2010, 11:25 PM | #15 | |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
http://rcpcrawlers.com/product.php?p...&cat=29&page=1 | |
11-27-2010, 05:40 AM | #16 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
i just bought axials cs. What is the difference in steering between positive and negative caster?
11-27-2010, 06:39 AM | #17 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Just having two options stinks. Go with a gunner beaf tube conversion and then add whatever C's you want and you win a the strength area as well.
11-27-2010, 09:28 AM | #18 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| cs
I like the axial ones .I didnt ise the set screws but i used buton head and have had no problem.
11-27-2010, 09:31 AM | #19 |
Pebble Pounder Join Date: Jan 2009 Location: Helsinki, Finland
11-27-2010, 09:46 PM | #20 |
| When you are setting up your upper links you can clock the axle up so that the pinion is pointed upwards towards the trany. This will help to give you better cleareance as well as putting less strain on the drive shaft. I try to get the drive shaft as straight as possible. Now that you have done this you need to clock your C hubs back the other way, otherwise your tires are pointed down as they turn. It is more noticible when you try to turn while climbing. Look at the pinion angle in the above pics the GUNNAR posted. |
