abadk9420's SNG Shafty Chassis Build Here is a list of what all is in my Comp Rig Specs: Chassis - East End Machining SNG Shafty Chassis Lower Links - East End Machining Delrin Links Front Straight, Rear Bent Upper Links - Front Traxxas Jatto tie rods, Rear Custom made Delrin Motor Mount - East End Machining heavy duty motor mount plate Transmission - Axial with RRP Aluminum Bottom gear, RC4WD Steel Idler and Top gears DIG - DNA Dig with Steel Internals Steering - Jet Boat BTA Steering setup Shocks - Duratrax DTXC9003 3.5" Axles - Axial - Front - S3R solid 1 piece steel lockers with HD gears Rear - S3R solid 1 piece steel lockers with HD under drive gears Knuckles - VP Aluminum High Steer knuckles C's/Lockouts - Axial Aluminum C's and Lockouts Wheels - VP DH2's Up Front SLW V4's out back Tires/Foams - HB White Dot Rovers - foams - F400 front and rear Drive Shafts - MIP C-spline CVD Drive Shafts Motor - Integy 35T ESC - Castle Creations Mamba Max BEC - Castle Creations BEC Batteries - 11.1 volt 3S lipo batteries Servos - Hitec 7955 steering and Hitec 5645 dig EEM Parts http://i303.photobucket.com/albums/n...10527Small.jpg New Transmission Case http://i303.photobucket.com/albums/n...10531Small.jpg Going together http://i303.photobucket.com/albums/n...10533Small.jpg http://i303.photobucket.com/albums/n...10534Small.jpg http://i303.photobucket.com/albums/n...10535Small.jpg http://i303.photobucket.com/albums/n...10536Small.jpg http://i303.photobucket.com/albums/n...10539Small.jpg http://i303.photobucket.com/albums/n...10540Small.jpg http://i303.photobucket.com/albums/n...10548Small.jpg http://i303.photobucket.com/albums/n...10555Small.jpg http://i303.photobucket.com/albums/n...10547Small.jpg http://i303.photobucket.com/albums/n...10554Small.jpg http://i303.photobucket.com/albums/n...10556Small.jpg http://i303.photobucket.com/albums/n...10557Small.jpg |
Very nice. |
Whats your WB at? |
Man? I thought you was gonna go moa???:mrgreen: Nice rig Curtis!"thumbsup" |
Looks Good!!"thumbsup" Can't wait to see how it does on the rocks for you... |
Are those Evader shocks? That is what they look like to me. if so are they front or rear shocks? (you left the shocks out of your specs...) Nice looking rig"thumbsup" |
You can do the shock mod by cutting the top off and drilling a hole in the top of the body and using a screw thru the hole to attach a rod end. I didn't really want to sacrafice the shock bodies incase I wanted to run the shocks on something else... so I came up with this: Take the ball part out of a Traxxas rod end and put some heat shrink tubing over it and put it in the shock body( you may need to ream the hole on the top of the shock a bit) once it is in there shrink the tubing. Works pretty well if you dont want to sacrafice the shock body... The heat shrink tubing will wear away eventually... so you will need to re-do to keep a tight fit in the shock. |
nice curtis"thumbsup" |
Just a small update on my build, I am now running VP DH2's up front and SLW V4's in the rear with custom cut panther F400 foams, I also just got a new body, here is a few pics of how it looks now. http://i870.photobucket.com/albums/a...40185Small.jpg http://i870.photobucket.com/albums/a...40106Small.jpg http://i870.photobucket.com/albums/a...40099Small.jpg |
Nice! Keep up the good work! |
HPI-Killer says badass rig man nice mod list, I think RCNT wants to see ur new lid indeed +1 Curtis great job |
That looks good. Are you still running the DNA dig? |
