Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: 1.9 axial wheel question
Old 05-16-2010, 03:45 AM   #1
Default 1.9 axial wheel question
i bought some 1.9 axial wheels for my 2.2 RTR scorpion and the wheel nut on the rig is too big for the wheels to fit, my question is what size nut do i need?
thank you!
LS1Armyboy is offline   Reply With Quote
Old 05-16-2010, 04:23 AM   #2
do you mean the hex nut? they are both 12mm, the stock ones have that little circle bump out on the front, you will have to drill the wheel to fit over this, or buy aftermarket ones that dont have it...
i hope it makes sense about the part im tlaking about, if not let me know and i will get a pic
ultimate_monkey is offline   Reply With Quote
Old 05-16-2010, 01:51 PM   #3
it doesnt make sense, yes i am talking about the hex nut, but the actual hex part wont fit into the wheel at all it seems to be a smaller size.
Old 05-16-2010, 01:54 PM   #4
I like to #*&^
buy a flat hex and you can still use the 2.2 witha flat hex
2500hdon37s is offline   Reply With Quote
Old 05-17-2010, 09:46 PM   #5
On the lookout for Rocks
constantmotion's Avatar
Yeah the AX-10 has the hexes with the tit on them and it won't fit 1.9 wheels. You'll need to grind the tit off or buy some flat hexes.
constantmotion is offline   Reply With Quote
Old 05-18-2010, 02:20 AM   #6
i use scx10 hexes. no nipple
AlphaQup is offline   Reply With Quote
Old 05-19-2010, 12:04 AM   #7
i just drilled the hole out on the wheels, all is well now, they fit, thanks for the help guys!!!
