Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Rear differential issues?
Old 05-17-2010, 07:25 PM   #1
Default Rear differential issues?
So, I notice that my rear wheels don't spin when I get a little bound up. So I start by lifting the front wheels a bit and hold the crawler back to see how much power it takes to make the rear wheels slip. With only a little throttle, the wheels offer no resistance and either the wheel hexes are gone or the differential has a problem. The driveshaft turns and I have previously CA glued one of the wheel hexes. Since both wheel are slipping, I think the rear diff is shot. Thoughts? Am I wrong?
This is a stock Axial and stock diff.
Kanine38 is offline   Reply With Quote
Old 05-17-2010, 07:50 PM   #2
Take it apart and have a look see
cr500rider is offline   Reply With Quote
Old 05-17-2010, 08:16 PM   #3
check that the driveshaft is still tight to the diff. mine come loose all the time, even when using blue locktite
racerjim is offline   Reply With Quote
Old 05-17-2010, 08:17 PM   #4
I really didn't want to do that until someone backed me up on my diagnosis.... Yeah, i'm a p*ssy.
Old 05-17-2010, 08:17 PM   #5
See, It's the simple things I overlook...
Old 05-17-2010, 09:08 PM   #6
Bingo! The set screws needed to be re-locktite'd. Thanks.
Old 05-17-2010, 09:24 PM   #7
See you can't be afraid to tear in and have a looksie thats how you learn it's usually the simple things too start there and keep going till you find the prob
Old 05-17-2010, 09:28 PM   #8
I really dont want to open up the diff until I put an underdrive gear set in it.
Old 05-17-2010, 10:21 PM   #9
why not?? all thats in there is a few bearings and a carrier for the locker, its not like a tone of little peices are gonna fall out
ultimate_monkey is offline   Reply With Quote
Old 05-17-2010, 10:27 PM   #10
Yes air I agree its really a simple set up and I like to do it right away anyways and grease stuff real good (doesn't seem like they put much in them when they assemble) You still have your manuel don't you ? it has an exploded view in it or you can download it from the axial site
Old 05-17-2010, 10:28 PM   #11
I like to #*&^
IMO the Axial axles are super simple! they take all of 15 min to take apart, clean, regrease/ replace a part, and put back together!
2500hdon37s is offline   Reply With Quote
Old 05-18-2010, 06:08 AM   #12
I just had rebuilt the shocks and taken apart the rear section a couple of times and I really didn't want to do it again... basically, I was lazy.
I will be taking apart the rear axle to run a underdrive gear set. Should I replace the locker at that point also or are they usually good to go?
Old 05-18-2010, 09:10 AM   #13
It should be good to go for a long time unless you have sheared it off or something just regrease ring and pinion real good after you replace them good luck (and get used to tinkering it's just part of the hobby) make shure your shimmed correctly when you do the ring and pinion swap
Old 05-18-2010, 10:00 AM   #14
Viva la SUPER
ram_tough's Avatar
Yes. Your axle should have the round green aluminium lockers, and should be replaced with the gray cross lockers.
ram_tough is offline   Reply With Quote
Old 05-18-2010, 10:32 AM   #15
Not always true, if theres a problem theres likley to be a ton of little peices falling out lol
allgm1 is offline   Reply With Quote
Old 05-18-2010, 11:29 AM   #16
SAVE BODILESS SPORTSMAN!!
Duuuuuuuude's Avatar
Not always. Both the ARTR and the RTR I bought had the grays.
Duuuuuuuude is offline   Reply With Quote
Old 05-18-2010, 03:28 PM   #17
Good to know... Thanks. Now I need to look for a dig.
Old 05-18-2010, 03:39 PM   #18
I like to #*&^
the only Axial kit to come with a locker was the orignal ax-10 KIT
Old 05-18-2010, 06:48 PM   #19
well in that case, what falls out is usually things u dont need in there any more any way
