| | #1 |
| Newbie Join Date: Dec 2009 Location: Westchester NY
| [IMG]file:///C:/Users/Brian/Desktop/new%20crawler/CIMG0093.jpg[/IMG]Hey everyone Im kinda new to the whole rc crawler thing. i have an AX10 with aluminum axles, proline 2.2 titus, flatirons, novak rooster esc and 55T, thunder tech driveshafts, TCS edge chassis Gmade shocks. I also have 4 link plates, but i am not sure how to set them up. its got 4WS, stock transmission with steel outdrives, and im running a spektrum dx5. Im wondering how to set up my 4 link. also i just put the prolines on today. they came with memory foam i wasnt sure if i was supposed to cut that type of foam down or not so i didnt, the tires seem ok but im wondering if i should trim it a little. any help would be appreciated. Brian |
| Sponsored Links | |
| | #2 |
| Here for booBs-n-Bacon! ![]() Join Date: May 2009 Location: Roseburg, Oregon
| Take a stroll through this thread: Edge Chassis Pics! |
| | #3 |
| Rock Stacker Join Date: Apr 2010 Location: El Paso
| And go..... My setup as follows: Bent lowers Shocks: Frame side on outer most hole on the outside. Axle on the outside of the tabs (closest to tire). droop setup with body on the axle side. Lowers: F/R: frame side-outer most hole on inside of frame (cut trans plate. Axle side - on the inside tab closest to pinion. uppers: front - frame side - Inner most hole to top of 4-link plate on axle. uppers: rear - Frame side - center hole to top of 4-link plate on axle. my belly height is 2 7/8" with rovers. a lot of people dont like the droop setup but i think it is because they have to make them work by trying different setups. mine seems to work in my location (desert/mountain) but i am always changing things. ![]() ![]() Even though i hope this will help, you will need to tweak it to your location |
| | #4 |
| Oh yea, Hammers were smaller so my belly height was about 2 1/4" and the foams were fine without cutting them. (that makes them smaller too) |
| | #5 |
| Rock Stacker Join Date: Jun 2009 Location: Fair Oaks
| i want those shocks i just bought an edge chassis from the for sale section and cant wait to start building. post some pics when your done so i can steal ideas |
| | #6 |
| SAVE BODILESS SPORTSMAN!! ![]() Join Date: Mar 2008 Location: Arkansas
| If you're going to comp, I'd ditch the aluminum axles, the short FI's, and the rear steer (not legal!). Otherwise it sounds like you've got a good start. |
| | #7 |
| thanks everyone and to scoobydan for the awesome pictures those answered a TON of my questions and really appreciate the help! |
| Thread Tools | |
| Display Modes | |
