Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Mods to My Ax10
Old 05-20-2010, 07:09 AM   #1
carp40's Avatar
Default Mods to My Ax10
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
carp40 is offline   Reply With Quote
Old 05-20-2010, 08:21 AM   #2
smokediver's Avatar
any info? looks like some zipties on an axle
smokediver is online now   Reply With Quote
Old 05-20-2010, 02:12 PM   #3
carp40's Avatar
The zip tires are just for some adjustible led weights. The copper upper links I made 70mm to give me more articulation I also drilled 4 holes in the chassis for the upper links to connect to. I also modded the bottom skid plate moved the lower links inside of the chassis and modded where the front and rear shocks mount to the axial for more articulation and less body torque.
Old 05-20-2010, 02:14 PM   #4
carp40's Avatar
