Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: dh procomp offset
Old 05-21-2010, 05:40 PM   #1
Default dh procomp offset
i got an ax10 what hubs for the front and rear
yfz350 is offline   Reply With Quote
Old 05-21-2010, 05:45 PM   #2
what do u mean?
NEW YORK BOY is offline   Reply With Quote
Old 05-21-2010, 06:22 PM   #3
Originally Posted by NEW YORK BOY View Post
what do u mean?
It really depends on what your looking for. I would say 460 front so that you have the option to fit zero ackerman knuckles and 335 rears. If your running or planning on super 300's then you might want to go 585 fronts just for more tire clearance.
Top_Ramen is offline   Reply With Quote
Old 05-21-2010, 06:45 PM   #4
im wanting to make the front wider rear the same as stock
Old 05-21-2010, 09:07 PM   #5
585's are stock offset, I clear everything pretty well (a little shock rub) with 300's, but really wish they made one or two offsets wider.
indiana mudcat is offline   Reply With Quote
Old 05-21-2010, 10:30 PM   #6
Village Idiot
DickyT's Avatar
Get the SLW 600, 725, or 850, they bolt right up. I have DH fronts and slw3 rears, 585's in the front and 335 DH hubs on the slw's in the rear.
DickyT is offline   Reply With Quote
Old 05-22-2010, 11:43 PM   #7
They bolt up, but I don't think they accept the weights as the hub goes into the weight area. I've thought about 3mm or 6mm Axial spacers between the wheel and hub with longer screws, but it looks like it would be real close to get my socket in to tighten the nuts down on the 300's, a thinner wall socket would work for sure, if I can find one. Or I could get some delrin and cut a star shaped spacer.
