| | #1 |
| Newbie Join Date: Jun 2008 Location: Sweden
| im thinking about buying my first crawler so can some1 give me a list and maybe a fhew links of the stuff i need and it would be appritiated p.s sorry for my bad spelling |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Jun 2009 Location: Fair Oaks
| i'm pretty sure axial offers a rear steer kit that should come with almost everything you need |
| | #3 |
| Newbie Join Date: Dec 2009 Location: Vancouver Wa
| Here's the link to the rear steering kit for the AX-10. http://www.axialracing.com/ftp/ax10options/ax30492.html Keep in mind that you'll also need a servo and a y-harness or a radio with an available channel that you can mix. You can also use a toggle that enables or disables the rear steering option. I suggest using a BEC and good batteries if you use top shelf servos. I'm sure there is more information in these forums on how to get it done. Last edited by makaluch; 05-26-2010 at 03:42 PM. |
| | #4 |
| Newbie Join Date: May 2010 Location: Virginia Beach
| I purchased the Axial Rear steer kit. It basically just comes with the links and the servo mount. I would use a 3 channel radio with mixing and you can do all kinds of cool stuff. I set mine up with a 4pk Futaba and it works great. Keep in mind, its just cool. Not allowed in comps. There is a link that has detailed setup instructions under I thnk the electronics thread. if you need any help, just let me know Barry |
| | #5 |
| but dont i need another axle with steering thingy on? look at the front axle on this link and you will get my point =P http://www.axialracing.com/ftp/ax10artr/ you can look at rear axle and you see theres no *steering stuff* on it. does that come in the fourwheel steering kit? |
| | #6 |
| No idea what I'm doing ![]() Join Date: Oct 2008 Location: Underground, CO
| You'll need the axle C's, knuckles, inner axle shafts and the outer axle output shafts along with bearings. You might want to save yourself the headache of piecing it all together yourself, and just order a complete axle when you buy your truck. $38.99 from TCS |
| Thread Tools | |
| Display Modes | |
