| | #1 |
| Newbie Join Date: Jul 2008 Location: CORNING
| Why do I keep Breaking CVD pins? |
| Sponsored Links | |
| | #2 |
| Latest NorCalRCRC slave ![]() Join Date: Dec 2008 Location: San Mateo, CA.
| Because you're not using mine |
| | #3 |
| Village Idiot ![]() Join Date: Oct 2007 Location: Hollywood, FL
| | #4 |
| 5th 2.2Pro Aust Nationals ![]() Join Date: Aug 2009 Location: Perth Australia
| X2, hopefully mine are crossing the Pacific as we speak. |
| | #5 |
| They should be there soon. I also think when using plastic knuckles and C's, when in a bind they might cause some deflection to the assembly, which could also stress the pin. There are some drawbacks to using stronger pins however: ![]() ![]() This is the stock axle hex pin that bent, the other two pins were in two different CVD's that were used in the rig during bind testing. I can help with this uncommon problem too: Last edited by gunnar; 05-26-2010 at 10:01 PM. |
| | #6 |
| RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| | #7 |
| I wouldn't say they are the best, it's really just a pin. With the smiley at the end, it was more of a joking reply. Anyone can get a length of music wire and cut their own pins, but I do try to make them as well as I can. |
| | #8 |
| Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
| Quote: |
| | #9 |
| Devoted axle fan ![]() Join Date: Nov 2008 Location: Greece, sun, sea and rocks
| Actually Gunnars' pins do hold up great. His hex pins saved me from continuous bent and broken stock hex pins. Heck I have even tried using 1/10 nitro touring pins to avail but his are holding still. |
| | #10 | |
Speaking of those, I've actually been making quite a few them today, up to about 150 or so now. There will be a giveaway coming up in a few months, this will be in a game show format, there should be ALOT of winners with this type of giveaway. It will either be the 10th or 17th of July. I'll post up reminders as we get closer to those dates, should be fun! | |
| Thread Tools | |
| Display Modes | |
