| | #1 |
| Rock Stacker Join Date: May 2010 Location: canvey island essex
| heres my ax10 i bought last month already had some work done to it like 4 link and a hot racing dig fitted.ihave also put axial alloy lockouts on rear as broke the others on first go .ive moved all the electrics to under the top platform for the cleaner look and low cg im trying to use this shell with out to much cutting but looks like i will have to cut or get another shell its running a lrp 21 turn brushless crawler set up and bluebird front servo im still getting used to it as normally run monster trucks or drift cars and i fancy a tuber chassis now as they look nice ![]() |
| Sponsored Links | |
| | #2 |
| | #3 |
| RCC Addict ![]() Join Date: May 2010 Location: So. Charleston. Wv
| Nice rig sir |
| | #4 |
| cheers mate |
| | #5 |
| | #6 |
| 5th 2.2Pro Aust Nationals ![]() Join Date: Aug 2009 Location: Perth Australia
| Looks cool man. you can probably mount the body a lot lower without cutting it. |
| | #7 |
| it will sit lower and work if i trim the arches down a bit .but may just by a shell already done as seems a shame to cut a decent shell up |
| | #8 |
| Rock Stacker Join Date: Jan 2010 Location: Marshall
| Nice, but I would mount your body lower and it looks like some of your tires are on backwards |
| | #9 |
| will check the tyres as thats how it came and shell was sitting on a cup inside just to show it on rig and im still using the purple cut down beetle shell for now as dont wanna cut new one yet lol |
| | #10 |
| managed to get 10 minutes to meself today no diy lol and its was running fine but once it got in a bind esc would shut down for 10 seconds then restart is that normal its a lrp crawler one |
| | #11 |
| i think ive sorted the prob as the lipo cut off it only allowing it to run down to just under 7 volts then cuting out . problem now is i cant seem to lower to cut of voltage and heres a pict of the beetle shell cut and fitted altho its a tad brittle as first roll and it split lol.i have put a pict in the beetle shell thread so hope its ok here aswell |
| Thread Tools | |
| Display Modes | |
