Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: clinger
Old 05-31-2010, 08:57 PM   #1
Default clinger
Click the image to open in full size.[/IMG]
heres a couple pics of the clinger i just put together with some extra parts i had laying around i'm running a 2 cell li-po with the novak rooster esc 2 208 ounce servos with a futaba 4ex its got about a half inch of ground clearance and complete extended it has 5 and a half inches
36dodge is offline   Reply With Quote
Old 05-31-2010, 09:31 PM   #2
Always fixing my stuff!
Crawling Calvin's Avatar
Man, puts a new term on "belly dragger"
I guess my question is, how well does it crawl compared to the original one. I hate floppy rigs so is it just like that or, am I wrong Not bashing your rig but it sure looks like an interesting vehicle to drive
Crawling Calvin is offline   Reply With Quote
Old 05-31-2010, 09:49 PM   #3
it does ok for now has alot of room for improvement the major thing is the tt so im going to try a sway bar on it. i want something different so i built a clinger i know it shouldn't work but thats the fun
Old 06-05-2010, 11:25 PM   #4
i have had a little time to fine tune it i put a sway bar on the front and put some 80 wt oil in the shocks and was able to limit the actuation to 5 inchs. seems like i have most the tt out of it also i got a bug body just need to paint it
Old 06-06-2010, 12:17 AM   #5
wow, that is a really low setup. Must be super stable though with such a low CG
turbobladz is offline   Reply With Quote
Old 06-06-2010, 10:14 AM   #6
SAVE BODILESS SPORTSMAN!!
Duuuuuuuude's Avatar
Hey you've got a build thread (kinda)!
Have you had it out on the rocks yet? It'll hang up less than you think it will.
Duuuuuuuude is offline   Reply With Quote
Old 06-06-2010, 01:14 PM   #7
yea ive had it out it does good the biggest impovement so far is the sway bar i need to change the chassis a little more so i can run my 4 links bars a little better. it will be a fun project next week im going to order bta steering for it and look into getting some different wheels, it needs alot of weight up front
Old 06-06-2010, 09:20 PM   #8
heres a couple of action pics with the new body
Old 06-06-2010, 09:48 PM   #9
which bug body is that?
Old 06-06-2010, 10:04 PM   #10
jcboof's Avatar
looks like the CKRC body.
jcboof is offline   Reply With Quote
Old 06-06-2010, 10:06 PM   #11
its the CKRC's Heavy Duty Baja Body here's a link http://www.ckrccrawlers.com/ckrcshea...dy-p-1818.html
Old 06-06-2010, 10:42 PM   #12
lol...nevermind.
Old 12-04-2010, 11:20 PM   #13
So....got an update?
Old 12-05-2010, 10:59 PM   #14
Default awesome
i want to build one out of some of the original ax 10 parts I have laying around, can you post better pics of the chassis and some of the build tech ????
nutoscaln is offline   Reply With Quote
Old 12-05-2010, 11:13 PM   #15
Search for "pirate clinger" and you'll find them.
Old 12-08-2010, 12:02 PM   #16
Default found it
thanks
