Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: DNA Dig problem
Old 06-01-2010, 10:21 PM   #1
Default DNA Dig problem
I have a DNA dig assembled, but the thing wont turn unless i force it to turn with a pair of pliers.
When i remove the dig from the tranny everything seems fine and spins fine.
So im lost confused right now...Help.
shelby is offline   Reply With Quote
Old 06-01-2010, 10:25 PM   #2
jcboof's Avatar
Is there a Brass pin that goes through the dig? Or is the output fully machined? Sometimes on the Brass pin version, the pin gets slightly tweaked out of place and it needs to get bent back.
jcboof is offline   Reply With Quote
Old 06-01-2010, 10:31 PM   #3
Yes there is a brass pin that goes through it.
What do you mean by bent back?
Old 06-01-2010, 10:38 PM   #4
jcboof's Avatar
make sure that that Pin is straight, Does it wobble when you spin it?? if it does, then bend it into a straighter position.
I'm not talking about the brass shaft that goes all the way through the dig assembly, that is the shift rod. I'm talking about a brass pin that comes out of the output of the tranny.
Old 06-01-2010, 10:43 PM   #5
No the only thing brass on it is that rod, the out puts are steel
Old 06-02-2010, 12:44 AM   #6
Get a Hurtz from VP and forget about headaches.
Waiting Dragon is offline   Reply With Quote
Old 06-02-2010, 01:04 AM   #7
I should of got a VP but i couldnt pass up $35 dollars for a dig.
Now i regret...
Old 06-02-2010, 02:20 AM   #8
abadk9420's Avatar
Check to make sure that the dig case is fully seated against the transmission case, also did you lightly lube all of the moving parts with some good grease? My DNA dig is very smooth and works great
abadk9420 is offline   Reply With Quote
Old 06-02-2010, 09:44 AM   #9
Make sure you did not overtighten the Dig to the Tranny case, I did and it was very hard for it to shift.
Also my output shaft on the dig was not drilled deep enough to allow the dig to engage. You should take the output shaft out and put it on the brass shaft and try to engage it on the output of the tranny, and see if they mate up. Mine did not I had to drill it out.
92LILREDYJ is offline   Reply With Quote
Old 06-02-2010, 10:18 AM   #10
jcboof's Avatar
Some of the DNA digs did not fit the tranny case perfectly so make sure it mates up nice and tight. If not, you can trim away some of the plastic on the lower portion of the trans. I never had one single problem with my DNA digs. And that was back when I was paying 90 to 100 bucks for them.
Old 06-02-2010, 11:24 AM   #11
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
This was the problem on my first one before DNA when they were VP.
Stormin2u is offline   Reply With Quote
Old 06-02-2010, 01:46 PM   #12
Awww man i feel like an idiot. Everything was fine i just forget to put a bearing back in the tranny , so everything is working smooth now
Old 06-04-2010, 12:05 AM   #13
I have an STRC skid plate but the DIG hits on the lower link when i try and bolt it on.
Any body expeienced this?
What should i do, grind the botton away so the link would clear?
Old 06-04-2010, 01:01 AM   #14
Can you put small spacers/washers (maybe 1mm or so) between the tranny and the skid and screw it back together to raise the tranny slightly? I dont see it making a noticable difference to your centre of gravity and then you might not have to grind anything.
axeten is offline   Reply With Quote
Old 06-04-2010, 07:33 AM   #15
Default I put washers on mine
I put washers on mine and I am pretty sure it has not cost me any comp points. I also had to grind up some of my dig for placement in my chassis and it all turned out fine. I had some setup issues with my dig as well but after I realized it was my fault I have been very happy with it.
RickM
RickM is offline   Reply With Quote
Old 06-04-2010, 11:32 AM   #16
you're not helping..
Krawl3r is offline   Reply With Quote
Old 06-04-2010, 01:26 PM   #17
Vp Monkey's Avatar
Can you clarify? dna is not VP.
Vp Monkey is offline   Reply With Quote
Old 06-04-2010, 02:03 PM   #18
Latest NorCalRCRC slave
gunnar's Avatar
I'm sure he meant VF- Visionary Fabrication. Just an unfortunate typo.
gunnar is offline   Reply With Quote
Old 06-04-2010, 03:37 PM   #19
I ground down my rod end to make it clear. I have been beating on it hard and the rod end have not givin up yet. I had even forgot I did that till you brought up the fit. lol
Old 06-04-2010, 03:49 PM   #20
Im also runing this on a eclipse chassis and the yolk on the drive shaft out put hits my upper link, so im just going to bring it down to the hobby shop and see what they say.
