| | #1 |
| Newbie Join Date: Jun 2010 Location: bowling green
| im new to rock crawling just bought a axial ax-10 rtc i want to change the three link to a four link on the front and rear how easy is it and what parts do i have to buy to do it ive already added 8 ounces of weight to the front tires and 4 ounces to the rear and cut the foams to make the tires a bit softer replaced the stock servo with a hitec 645 and notched the skid plate to put the lower links inside the chassis any other ideas on some easy and cheap mods |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jan 2009 Location: Langley, BC, Canada
| 4 link is easy. try TCS, or http://www.rccrawler.com/forum/showt...light=template You can play with the link length to adjust your driveling angle. You can buy aluminum tube at most hobby shops, and get yourself a 3mm tap, and some set screws to make your own links, or just buy Axial links, and link ends. Use the search button, and you will find endless info on how to maximize your AX-10 setup. |
| | #3 |
| Always fixing my stuff! ![]() Join Date: Oct 2009 Location: Thousand Oaks
| Another super easy, and cheap trick, to (slightly) change the link size is with different thicknesses of small washers |
| | #4 |
| RCC Addict ![]() Join Date: Oct 2008 Location: Topeka, IN
| Building links is easy too. You can use Delrin Rod and drill the ends for set screws or use 8/32 all thread and 1/4" brake line and make your links. SUPER EASY! |
| | #5 |
| Newbie Join Date: Aug 2009 Location: Valdese
| I generally make my own links, used both aluminum and delrin. Aluminum tends to hang up quicker and can be bent due to a nasty tumble. The delrin is easy to work with and is not much more expensive than the aluminum, but tends to pre-load when put in a bind and springs unpredictively. As far as 4-link plates, get one with plenty of mounting options so you get to tinker |
| | #6 |
| SAVE BODILESS SPORTSMAN!! ![]() Join Date: Mar 2008 Location: Arkansas
| Would somebody please alert the UN that Holland is out of periods and commas? |
| Thread Tools | |
| Display Modes | |
