07-27-2010, 01:22 PM | #21 | |
07-27-2010, 07:23 PM | #22 | |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
Kieren | |
07-31-2010, 12:38 AM | #23 |
Just some pics from today's crawl session. Once again at Neilson beach. Can get a very nice 1.5 hours out of a single 1100mah pack! Kieren The orange safety barrier in the first pic is my leg |
08-05-2010, 05:27 AM | #24 |
Pebble Pounder Join Date: Mar 2009 Location: Germany / Stuttgart
Hi Kiren, the weight sounds very interesting Uups a broken leg. Greetings - Sascha |
08-05-2010, 05:46 AM | #25 | |
Not quite only some tendon damage. Kieren | |
08-11-2010, 06:05 AM | #26 |
I'm not liking the scrub from the new hubs so I decided to fix that. A little bit of shaving and some new holes and what do you know highly clocked ax10 axles. I'm also working on a new low as possible steering set up. I was going to go back to mid steer knuckles, but after clocking the high steers have enough room anyway! I just have to make plate for the links, a mount for the other side of the servo and some new links. The advantage of it now is that everything is resting on the axle nice and low. Also it is not sticking out so far so it is protected nicely. The futaba was getting a few to many scratches for comfort |
08-11-2010, 09:03 AM | #27 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Steering came out nice, much easier when no shocks are in the way. Are any tubes used inside the housings to help strengthen the new clocking idea? Dig servo mount good too, nice way to do it with the standard mounting point on the dig case. Last edited by gunnar; 08-11-2010 at 09:06 AM. |
08-11-2010, 11:01 AM | #28 | |
Thank you Kieren | |
08-11-2010, 11:15 AM | #29 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
I've been wondering why I couldn't get more steering out of my axials! it's because you've been hogging all of it! lookin real good mannnnn! |
08-11-2010, 02:09 PM | #30 |
Looks great man. Keep it up Love the way the servo tuck's into the rim like that. So no reinforcement of the axle housing? Just shave down the index on the housing, clock the c's and re-drill? Last edited by TSK; 08-11-2010 at 03:37 PM. |
08-11-2010, 04:36 PM | #31 | ||
None as such at the moment, but I might do something yet I'm not sure. Yeah that is fairly well the procedure. Kieren | ||
08-13-2010, 06:09 AM | #32 |
Did a bit more on the front axle today Kieren |
08-13-2010, 03:14 PM | #33 |
That turned out killer. Now get out there on beat on it. I wanna see how the shaved axle housing hods up,
08-15-2010, 05:07 AM | #34 |
Finished up the last bracket on the servo mount and took it out for a test run. The bracket needs a little tidying up but otherwise the steering set up is finished. She also worked very well. I think it is getting very close to dialed. Just practice, practice, practice. Also got some boss claws on the way too. We'll see how they work. Thank you TSK Yeah it held up fine in initial tests. Kieren Last edited by Aussie Nerd; 08-15-2010 at 10:44 PM. |
08-15-2010, 09:29 PM | #35 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
FYI running the c's without any internal supports is asking for trouble. I did that and had the plastic crack, so you need something on the inside. Doesn't have to be a ton, but something for the screw to "hold into" and let friction... do the rest. I intentionally turned my inner tubes a little "to big' and left the surface sorta rough so they would grab better, so far noooo issues PS: hows your leg doing |
08-15-2010, 10:45 PM | #36 |
Yeah you have me thinking, I might try put some 'epoxy steel' or something like that just to strengthen it up a bit. Leg is alright thanks gone from cast to 'boot' now. Kieren |
08-17-2010, 03:10 AM | #37 |
Just got some better pictures of the steering set up. I tidied up the mount on the other side. Also the new weight with everything bar rims, batteries and body is 1135g. For those with the weight fascination I have netted a 25g loss with the new steering set up and battery mount. Also some with a sharp eye may have noticed I have 'reversed' my link/mid link set up. More steering clearance and a little firmer 'shock' movement good all round! Kieren |
08-17-2010, 10:54 PM | #38 |
How does the steering feel like that? Has it taken any big falls yet? I have extra housings nad some plastic c's I can play around with but still not convinced that I wanna go that route yet.
08-18-2010, 01:42 AM | #39 |
I like it a lot, make's using such wide hubs bearable. No not yet, I have only run on the practice course. I really should put something in there to beef it up, but I'll try it as is for the moment anyway. Kieren |
08-19-2010, 09:52 PM | #40 |
Got some new shoes. They are a bit of a pain to mount and the release compound on the tires makes them filthy when they arrive, but a quick wash and dry, and using some bit longer bolts to get them started, they aren't too bad. The compound feels great after you wash it. First impressions just digging around on tiles, was In the same situation the rovers would slide or sit there and hop. I had to back the power off because I though I was going to break something they gripped that well! I also have switched too a DX3e in this rig so I can 'share'. The berg will get the DX6p. I think specktrum surface receiver designers need to take their course again. It is over twice the footprint of my fxr! Also when I opened it to coil the antennae they could have easy taken 5-10mm of circuit board off the end, it has nothing on there. Anyway it fits and it works well so I guess I can't complain to much. Kieren |
Tags |
aussie nerd, sss, sss-r, torsion |
