08-10-2010, 01:10 AM | #21 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Here she is. The specs: Bad Man Fastback - Thank You Juan and Underground Crawlers Krawler Konceptz Skinz - Fastback Edition - Thank You Michelle Tekin FXR CKRC 35t Twister VP Hurtz Dig CKRC BTA with Axial knuckles Futaba 9157 Steering Servo Overdrive gears in the front. 1300mah LiPo. Castle Creations BEC Rovers front and rear with some Nova's in the rims. Soon to come, Losi shocks and some Vanquish DH pro comps for the front and SLW's for the rear. And the pics. |
08-10-2010, 06:34 AM | #22 | |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
that looks awesome bigstu great looking build | |
08-15-2010, 06:56 PM | #23 |
I was talking with Flapjack this weekend, and realized I didn't have my own in here This was taken without my sidepanels....I was waiting for my KrawlerKoncepts skins which just showed up I normally prefer Yellow, but I had this leftover from my SCX build, so I thought I'd try an RCC themed scheme. Here's my specs. Underground Crawlers Fastback Chassis Holmes Hobbies TorqueMaster BR-XL ESC Holmes Hobbies TorqueMaster Pro Handwound 45T Holmes Hobbies 25C 1300mah lipo Axial Comp Shocks Axial Overdrive gears front Axial Heavy Duty Lockers Axial BTA White rovers on my own wheels Nova dd foams VP dig Hitec 7950th Steering Servo |
08-16-2010, 08:54 AM | #24 |
Pebble Pounder Join Date: Jul 2010 Location: St. George
Looks sweet Juan. I did notice that your mounting location for the front uppers is quite a bit different then most of the others - care to share the philosophy there ? I'm doing a rebuild and I'm curious how that woks. SG |
08-16-2010, 09:48 AM | #25 |
| I'm currently running a 3-link in the front with the Axial BTA. I plan to make a new front plate that will allow me to run a 4-link, and clear the the BTA better.
08-16-2010, 10:47 AM | #26 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
Iam about to pull the trigger on a Fastback it looks like a great platform for a shafty. And after seeing the ones in this thread and seeing one at the comp. this weekend(and it looked like it was working great) Iam hooked |
08-16-2010, 11:06 AM | #27 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
Ordered my FB last night... Can't wait to get it!
08-16-2010, 11:19 AM | #28 |
09-03-2010, 12:02 AM | #29 |
Phase 2, some more goodies. VP DH Pro Comps in the front. VP SLW in the back. New set of HB Sedonas. Set of Losi Crawler shocks, 60wt in the corners that matter, 30wt in the ones that don't. New driveshaft in the front, with some collars. Trying to keep the shaft in the car and not in pieces on the ground. Some new 1100mah MaxAmps Lipos, smaller and better burst rate. Now if it would just stop raining and dry up so I could go out and get some practice. First comp is next weekend, so I need to get ready. Anyway, here are the pic. |
09-03-2010, 08:23 AM | #30 |
Quarry Creeper Join Date: Jul 2009 Location: Derby
Here's mine.. but you have to let me in as it's using LCC running gear Juan's most excellent Fastback chassis Stock LCC tranny on a 70mm skid Losi MX-12 dig servo Stock LCC axles R2J fat bent lower links LCC upper links in rear All thread and stainless tube links in front Losi Comp shocks 50wt gold springs in front white in rear Hobbico CS-170 Servo CC BEC Mamba Max Pro Losi 21.5t BL with 13t pinion Picture shows DNA assassins with Rovers, Currently running Boss Claws on VP DH's. (from Berg in the background) Nova Ark foam's in front, stock in the back (for the Claws and Rovers) Krawler Koncept skins on the way Last edited by jkwrangler08; 09-03-2010 at 08:28 AM. |
09-08-2010, 03:53 AM | #31 |
Quarry Creeper Join Date: Jan 2010 Location: UAE in the GCC
not the standard axial but definitely a fastback!!! Specs: Underground Crawlers Fastback Chassis Gmade R1 Portal Axles Custom Gmade R1 Shock & Lower Link Mount Losi 4" Shocks 40wt shock oil white springs R7R Long Skid Plate R7R R1 Delrin Lower Rear Links Custom Delrin Front Lower Links Custom Aluminum Front & Rear Upper Links Custom Acrylic Battery Plate w/ upper link mount Gmade R1 Adjustable Upperlink Bracket (rear) Gmade R1 Dig Unit MIP CDV Drive Shafts Gmade R1 Transmission Proline Titus 2.2 Front & Rear HB White Dot Rovers Electronics: Novak Goat 3s Esc Novak 3amp 6v BEC JR DS8411 R2 Aluminum Servo Horn Futaba S3003 Dig Servo Spektrum SR300 Novak 18.5 Brushless Futaba 3PK with Spektrum Module |
09-08-2010, 06:09 AM | #32 |
these fastback's look totally awesome thanks juan! |
09-08-2010, 07:23 AM | #33 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Heres my. Its based on the one crawler everyone likes to hate Base: Venom Creeper Chassis: Underground Crawlers Fastback Shocks: Traxxas Hard Ano'd Big bores, 20wt, CKRC "silver" springs rear, stock Creeper blacks front Tranny: Ax10 Motor: Integy 50t "twin turbo mod" ESC: Castle creations Sidewinder Servo:Savox SC-0252. Tires: White Rovers with RMDW Paradox foams Wheels: Axials (weighted front only) Other stuff: Custom servo batt plate, Flm spools, RMDW rear upper link plate, Custom skins This should be in general crawlers cause there three rigs in here that arent Axials |
09-08-2010, 10:32 AM | #34 |
09-08-2010, 10:47 AM | #35 | |
thanks SG ..... the portal axles with the fastback work great ..... i'd say pro-shafty capable in the hands of a good driver!!! well ...... im a filipino architect based in the UAE .... not much crawlers here though to set up comps but we do have our fair share of fun ..... "Rc crawling will get big here" ..... hehehe ... i will have some videos up very soon!!! thanks for the thumbs up! cheers!!! | |
09-08-2010, 11:00 AM | #36 |
09-08-2010, 05:45 PM | #37 |
Quarry Creeper Join Date: Oct 2008 Location: Valley Village
| UGC Fastback |
