08-17-2010, 09:15 PM | #1 |
Newbie Join Date: Aug 2010 Location: sun valley
| new to the forum and need help
i got a axial ax 10 that i was puting together and i got a 45t motor but it goes slow on forword and is a lot faster on reverse can i get some help on reversing that i'm not new to rc's but i i'm new to crawlers and electric is it my esc or motor
08-17-2010, 09:19 PM | #2 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
OK, post up some specs. What radio? What receiver? What ESC? Casey |
08-17-2010, 09:20 PM | #3 |
Pebble Pounder Join Date: Jun 2008 Location: PISCATAWAY
what esc are you using
08-17-2010, 09:22 PM | #4 |
Quarry Creeper Join Date: Sep 2009 Location: Abbotsford BC
If your radio has adjustable end points it could be that the forward throttle is being stopped. But it's been my experience that thats normal... the motor spinning faster in one direction than the other. You could either flip your tranny around and revers the throttle on your transmitter OR solder the motor on the other way and reverse your throttle on your transmitter.
08-17-2010, 10:30 PM | #5 |
[thanks guys for the quick respon that crawler that i was working on is for my 4 year od so i just gave him a reguler axial radio and i lrp esc that i got out from a older car and i hard the same problem with the one i have but i got a dx3s radio so i was abel to fix that with the radio but i don't know about that radio or what can i do
08-18-2010, 11:43 AM | #6 |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
Sounds like the motor wires could be on backwards, many radios and esc's limit the power in reverse. I had this problem on my CK, had the radio set to reverse signals and it was slow in forwArd. Switched the wires and the reversing switch and it was fine.
08-18-2010, 08:46 PM | #7 |
i did do the wire change but still the same i'm going to change the trany see if it will work
08-18-2010, 09:27 PM | #8 |
Read this. http://www.rccrawler.com/forum/showt...89#post1247489 At the top of each thread section there are informative threads permanently stuck to the top for easy reference. There is a ton of good info to be found. The link I gave you is from the Electronics section. Since you are new, I highly recommend you browse through and study up a bit. It'll do ya good and save you from a lot of future head scratching. Welcome to the site! |
08-18-2010, 10:26 PM | #9 |
thanks guys for all your help i fix the problem i just changed the axial the fornt i move it to the back nd the back to the front i don't know if theres a front or back to the chassie but it worked and that what counts thanks agen
08-18-2010, 10:36 PM | #10 |
08-19-2010, 06:39 AM | #11 |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
