08-28-2010, 03:53 PM | #1 |
| Slipper Questions
I am going to upgrade my internal gears shortly on my AX10 comp rig and not sure how to get the Axial tranny to run w/o a slipper. Do you just take off the slipper pad and tighten the nut all the way down w/o the spring? Also for those of you running a slipper how tight do you set it? I have mine screwed all the way in and loosened about a quarter turn. |
08-29-2010, 12:49 AM | #2 |
Newbie Join Date: Mar 2010 Location: australia
i have my slipper set almost full loose and it still barley slips...maybe mines special lol
08-29-2010, 11:57 AM | #3 |
Newbie Join Date: Jul 2010 Location: San Diego
I run mine fairly loose. step on the back tires, and hit the gas. front end barley lifts. If you have any plastic parts to tight on the slipper will twist/bend em. You want enough torque getting through to crawl, but also want to protect the parts. If you really don't want a clutch in it, a little CA on the slipper disk will lock it solid.
08-29-2010, 07:54 PM | #4 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
if you rebuild your tranny without the slipper you will need the shorter top shaft... axial part# AX30197 |
08-29-2010, 08:12 PM | #5 | |
08-29-2010, 08:20 PM | #6 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
10-10-2010, 09:19 PM | #7 |
RCC Addict Join Date: Jan 2010 Location: Dallas
| tonights mod
So I was having problems with my slipper constantly loosening up and slipping when the bind I was in was not even that bad. So I did a mod tonight. I drilled out the back plate (the tranny side) of teh slipper assembly. I then used a longer 3 mil screw though the spur gear. Anyway the 3 mil went all the way though and I now have no slipper without the hassle of ordering all these new parts.
12-03-2010, 10:37 PM | #8 | |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
I like the free slipper mod. Thanks Rick Quote:
12-04-2010, 06:20 AM | #9 |
Hey, glad to help you not spend money on some things when we know we all spend to much on this crazy hobby anyway.
12-05-2010, 10:06 PM | #10 |
Newbie Join Date: Jan 2010 Location: phoenix
| can you post apic of the mod
that is a solid mod, would you mind sharing a pic?
