11-16-2010, 09:59 PM | #21 | |
It'll help when you turn. | |
11-16-2010, 10:01 PM | #22 | |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
i've never run the motor before, i've always wanted to try one so I decided I might aswell, I will review it after its been tested, i'm unsure how it'll hold up with a 19 or 21 t pinion, i'm used to running a 14, but i'd like a bit more wheelspeed, I did get it from shaver's. | |
11-16-2010, 10:02 PM | #23 |
| i've thought about doing this I will try it as is, as it seems to be an improvment over stock, and try toeing out if neccisary, thanks |
11-16-2010, 10:06 PM | #24 |
Mine is toed out even though its right without the adjustment. Seems to hold a line better when turning.
11-16-2010, 10:07 PM | #25 | |
Rock Crawler Join Date: Sep 2009 Location: Temecula Ca
11-16-2010, 10:09 PM | #26 |
RCC Addict Join Date: Jul 2009 Location: Santa Rosa, CA
| So doing this could help you turn better? Could I do this by just making my steering tie rod bar longer?
11-16-2010, 10:11 PM | #27 | ||
thanks for the tips Duuuuuuuude Quote:
yes, I will likely add a longer spacer in place of my 2 little ones, I need those little ones for something else that I had forgot about. | ||
11-16-2010, 10:19 PM | #28 |
11-17-2010, 05:55 PM | #29 |
just wanted to say thanks alot for the help, I removed the 2x2mm shims and added 1x6mm shim, it appears to be the proper length tierod now, looks like no toe in or out, and both hubs steer to way more now might still try a hair of toe out, once i've tested it. pics soon, I just finnished up the front axle, didn't do the beef toobs yet but thats ok, they arn't going anywhere, i'd like to do the front and rear at the same time anyway Last edited by fred0000; 11-17-2010 at 05:57 PM. |
11-17-2010, 07:09 PM | #30 |
got it temporaraly assembled in the chassis, looks pretty goof to me, except my wheelbase is pushing 12 7/8" and new steering angle pics |
11-18-2010, 05:09 PM | #31 |
I test drove it this afternoon with everything just taped on, the steering seems to work, but somtimes when turned to the right the servo seems to stall out? and not want me to do anything till I let off the throttle, to the left there are no issues. the servo got quite hot too. I'm not sure my setup is very friendly to the servo especialy turning left. as this causes the draglink and hightsteer arm to be in a straight line, I could see this being very demanding of the servo since it has almost no leverage at that point. (you can see if in the last picture in my last post) as much as I dont want to, I think I will be returning to OEM style steering knuckles till something can be figured out, my servo has never gotten that hot, and i've run back to back packs through it for 2+hours. my BEC is set at 6.5 volts, going through my reciever.
11-18-2010, 08:17 PM | #32 |
Rock Crawler Join Date: Jul 2010 Location: St. Albans
So how does it crawl with the 4 link compared to the 3 link Just wondering cause im ready to fab me up some plates.
11-18-2010, 08:22 PM | #33 | |
I did start cutting new skins, these feel like they will hold up much better, i'm using some plastic file folder I got from wal-mart instead of tin cans. also thinking I might need some driveshafts, the integy CV shafts I have are in rough shape, the slot for the CVD pins are rounded right out on a few of the yokes, i'll use them as I look for another option. | |
11-20-2010, 02:01 PM | #34 |
so skins are cut and installed, now its down to laying out the electronics, I dont really want to mount the battery to the top of the rear links again, but it seems like I might have to complete skins atleast 1 good thing about the bad weather, I have lots of time to work on my crawlers |
11-20-2010, 03:12 PM | #35 |
Rock Stacker Join Date: Oct 2010 Location: home of the beaver
11-20-2010, 03:32 PM | #36 |
o and nice skins
11-20-2010, 03:48 PM | #37 | |
thanks, I like them alot better then the tin cans, feels way more sturdy too, shouldn't be tearing the zip ties through very easily now | |
11-20-2010, 04:01 PM | #38 |
did some re-wiring today, the signal wire castle decided to use is better suited for the inside of a cell phone, that shit was brutal, I wanted to trim the length of my BEC singal wire anyway, so I used that to replace the tiny factory wires. also removed my on/off switch, didn't see the point in having it with a BEC, I also added a plug inline the battery wires for the BEC since castle-link doesn't like to "see" the BEC if its attached to my sidewinder. I wish I had shortened the BEC power wires but oh well, i'm sick of soldering! now I can start finding a place for all this in my crawler |
11-20-2010, 05:09 PM | #39 |
IT MOVES, it drives it crawls heres a couple test flex pics. yes, I made my RTI ramp out of oak. I was bored at work. |
11-21-2010, 07:43 PM | #40 |
I was doing some reading and found out my recievers can run on up to 7.4 volts, so I will be upping the voltage output on my BEC (good thing I put that plug on there ) to 7 volts. I run it at 6.5 right now and its good, so I don't want to push it to the limit, I don't to kill the gears in the serve since I cheaped out and went for a steel gear unit I also got a digital scale while it was still onsale and weight my crawler. it is much lighter then I expected, and the weight bias is better then I thought considering the amount of weight I have in the front wheels compared to the rear (pic on page 1) Total: 6 pounds 7.7oz Front: Rear: (note no battery) Last edited by fred0000; 11-21-2010 at 09:22 PM. |
