![]() | #1 |
Rock Stacker Join Date: Aug 2010 Location: Stewartstown
i have a couple questions about the super 300. i have to drill the bevel gear and the wheel hexes out in order for these to work and fit correct? also what exactly am i drilling on the bevel gear to make it fit on the new locker? are the threads one size bigger then stock for my wheel nut. i thought stock was only 4mm and they are saying 300's are 5 mm threads is thsi correct?
![]() | #2 |
Newbie Join Date: Apr 2015 Location: Keizer
I would like to know this myself ....I would also like to know what kind of aluminum wheels I could use with these?
![]() | #3 |
Try to Bend it ![]() Join Date: Aug 2009 Location: Perth Australia
Yes, Yes and Yes. Drill the central hole of the Bevel gear to 6mm slightly larger is better 6.05mm same with the hexes. You will need M5 wheel nuts some thing else you will need is 2 of 11 x 6 x 4mm bearings to replace the c hub bearings. You can use any aluminum wheels you like, but bare in mind they may also require drilling. |
