Now for the links http://i490.photobucket.com/albums/r...C/IMG_1020.jpg http://i490.photobucket.com/albums/r...C/IMG_1021.jpg http://i490.photobucket.com/albums/r...C/IMG_1022.jpg http://i490.photobucket.com/albums/r...C/IMG_1025.jpg Made the steering rods http://i490.photobucket.com/albums/r...C/IMG_1030.jpg http://i490.photobucket.com/albums/r...C/IMG_1031.jpg http://i490.photobucket.com/albums/r...C/IMG_1032.jpg Then the uppers http://i490.photobucket.com/albums/r...C/IMG_1050.jpg http://i490.photobucket.com/albums/r...C/IMG_1053.jpg http://i490.photobucket.com/albums/r...C/IMG_1054.jpg http://i490.photobucket.com/albums/r...C/IMG_1056.jpg Then did a little work with some tubing to make everything pretty http://i490.photobucket.com/albums/r...C/IMG_1070.jpg I think it works pretty good http://i490.photobucket.com/albums/r...C/IMG_1078.jpg Now I decided to give it a real low crawl ratio via this http://i490.photobucket.com/albums/r...C/SAM_0166.jpg The reduction box itself http://i490.photobucket.com/albums/r...C/SAM_0168.jpg Little trimming http://i490.photobucket.com/albums/r...C/SAM_0171.jpg http://i490.photobucket.com/albums/r...C/SAM_0172.jpg http://i490.photobucket.com/albums/r...C/SAM_0173.jpg I did a test fit with an old motor I had and its tight but fits http://i490.photobucket.com/albums/r...C/SAM_0177.jpg |
Shocks: http://i490.photobucket.com/albums/r...C/SAM_0319.jpg Wheels/Tires: http://i490.photobucket.com/albums/r...C/SAM_0320.jpg http://i490.photobucket.com/albums/r...C/SAM_0321.jpg And The cherokee body: http://i490.photobucket.com/albums/r...C/SAM_0326.jpg Without shocks: http://i490.photobucket.com/albums/r...C/SAM_0325.jpg Now with: http://i490.photobucket.com/albums/r...C/SAM_0328.jpg http://i490.photobucket.com/albums/r...C/SAM_0329.jpg http://i490.photobucket.com/albums/r...C/SAM_0330.jpg http://i490.photobucket.com/albums/r...C/SAM_0332.jpg http://i490.photobucket.com/albums/r...C/SAM_0334.jpg http://i490.photobucket.com/albums/r...C/SAM_0335.jpg Next to its big brother: http://i490.photobucket.com/albums/r...C/SAM_0338.jpg http://i490.photobucket.com/albums/r...C/SAM_0339.jpg It sits a bit to high for my liking but it will work. |
Now to cut the body up http://i490.photobucket.com/albums/r...C/SAM_0343.jpg http://i490.photobucket.com/albums/r...C/SAM_0340.jpg Needs to be comp cut in the rear and major fender trimming up front http://i490.photobucket.com/albums/r...C/SAM_0344.jpg Still need more V V V Better http://i490.photobucket.com/albums/r...C/SAM_0345.jpg http://i490.photobucket.com/albums/r...C/SAM_0346.jpg Now onto the rear http://i490.photobucket.com/albums/r...C/SAM_0341.jpg before V V V That's better http://i490.photobucket.com/albums/r...C/SAM_0348.jpg http://i490.photobucket.com/albums/r...C/SAM_0349.jpg http://i490.photobucket.com/albums/r...C/SAM_0350.jpg http://i490.photobucket.com/albums/r...C/SAM_0351.jpg Now I just need to go mount it up. Mounting the body It starts here: http://i490.photobucket.com/albums/r...C/SAM_0352.jpg Then mounted these: http://i490.photobucket.com/albums/r...C/SAM_0353.jpg like so: http://i490.photobucket.com/albums/r...C/SAM_0354.jpg made holes in the body: http://i490.photobucket.com/albums/r...C/SAM_0355.jpg and there you go. http://i490.photobucket.com/albums/r...C/SAM_0356.jpg http://i490.photobucket.com/albums/r...C/SAM_0357.jpg Need to do more trimming, probably going to comp cut the front too http://i490.photobucket.com/albums/r...C/SAM_0358.jpg and need more cutting in the rear http://i490.photobucket.com/albums/r...C/SAM_0359.jpg |
Some shots of how it looked at this step. http://i490.photobucket.com/albums/r...C/SAM_0360.jpg http://i490.photobucket.com/albums/r...C/SAM_0361.jpg http://i490.photobucket.com/albums/r...C/SAM_0362.jpg http://i490.photobucket.com/albums/r...C/SAM_0363.jpg http://i490.photobucket.com/albums/r...C/SAM_0364.jpg http://i490.photobucket.com/albums/r...C/SAM_0365.jpg http://i490.photobucket.com/albums/r...C/SAM_0367.jpg http://i490.photobucket.com/albums/r...C/SAM_0366.jpg http://i490.photobucket.com/albums/r...C/SAM_0368.jpg http://i490.photobucket.com/albums/r...C/SAM_0369.jpg http://i490.photobucket.com/albums/r...C/SAM_0370.jpg http://i490.photobucket.com/albums/r...C/SAM_0371.jpg http://i490.photobucket.com/albums/r...C/SAM_0372.jpg http://i490.photobucket.com/albums/r...C/SAM_0373.jpg http://i490.photobucket.com/albums/r...C/SAM_0374.jpg http://i490.photobucket.com/albums/r...C/SAM_0378.jpg http://i490.photobucket.com/albums/r...C/SAM_0379.jpg http://i490.photobucket.com/albums/r...C/SAM_0380.jpg |
Homebrews kick ass "thumbsup" |
I painted the body today http://i490.photobucket.com/albums/r...1/SAM_0467.jpg http://i490.photobucket.com/albums/r...1/SAM_0468.jpg http://i490.photobucket.com/albums/r...1/SAM_0474.jpg http://i490.photobucket.com/albums/r...1/SAM_0473.jpg http://i490.photobucket.com/albums/r...1/SAM_0469.jpg http://i490.photobucket.com/albums/r...1/SAM_0470.jpg http://i490.photobucket.com/albums/r...1/SAM_0471.jpg http://i490.photobucket.com/albums/r...1/SAM_0472.jpg |
Did some work started by taking the tranny out http://i490.photobucket.com/albums/r...C/SAM_0587.jpg Did some trimming http://i490.photobucket.com/albums/r...C/SAM_0588.jpg But realized I trimmed the wrong area at first, so I trimmed the area I needed too. http://i490.photobucket.com/albums/r...C/SAM_0589.jpg Then cut some aluminum http://i490.photobucket.com/albums/r...C/SAM_0590.jpg http://i490.photobucket.com/albums/r...C/SAM_0591.jpg Drilled some holes http://i490.photobucket.com/albums/r...C/SAM_0592.jpg And here is how it looks now, just need the motor to fill it up. http://i490.photobucket.com/albums/r...C/SAM_0593.jpg http://i490.photobucket.com/albums/r...C/SAM_0594.jpg Here is a mock up with my "test motor" http://i490.photobucket.com/albums/r...C/SAM_0595.jpg http://i490.photobucket.com/albums/r...C/SAM_0596.jpg |
Got most of the stuff together. http://i490.photobucket.com/albums/r...C/SAM_0616.jpg I needed a spacer to mount the motor against, so I made one out of wood http://i490.photobucket.com/albums/r...C/SAM_0617.jpg Here is the motor with the pinion gear on http://i490.photobucket.com/albums/r...C/SAM_0618.jpg The gear reduction box http://i490.photobucket.com/albums/r...C/SAM_0621.jpg http://i490.photobucket.com/albums/r...C/SAM_0622.jpg Then soldiered the motor to the ESC http://i490.photobucket.com/albums/r...C/SAM_0623.jpg http://i490.photobucket.com/albums/r...C/SAM_0624.jpg Then went to getting the steering all set up http://i490.photobucket.com/albums/r...C/SAM_0625.jpg http://i490.photobucket.com/albums/r...C/SAM_0627.jpg Then after doing some testing, I found the reduction box was way to much, the tires barley turned with the motor run at full blast. So I just used the tiny pinion gear and it moves at a walking pace. http://i490.photobucket.com/albums/r...C/SAM_0628.jpg http://i490.photobucket.com/albums/r...C/SAM_0629.jpg http://i490.photobucket.com/albums/r...C/SAM_0630.jpg http://i490.photobucket.com/albums/r...C/SAM_0631.jpg |
These are some videos to go along with it. http://www.rccrawler.com/forum/videos/267571-my-crawler.html |
A while ago I had dropped it and broke the upper link connector. Well I finally fixed it. http://i490.photobucket.com/albums/r...C/SAM_0729.jpg new 3 link connectors to fix it. http://i490.photobucket.com/albums/r...C/SAM_0772.jpg yup http://i490.photobucket.com/albums/r...C/SAM_0773.jpg And reinstalled http://i490.photobucket.com/albums/r...C/SAM_0774.jpg I had at some point changed to a servo horn instead of a servo saver, I never was able to use it though when I broke the first 3 link connector. http://i490.photobucket.com/albums/r...C/SAM_0776.jpg Then took a couple minutes and cut the ends of the shock screws and the sharp corners of the chassis down http://i490.photobucket.com/albums/r...C/SAM_0778.jpg |
This is sweet. I love homebuilds and the drill idea for a reduction was a great idea. |
I recently made a camera mount for on board video. http://i490.photobucket.com/albums/r...C/SAM_0968.jpg http://i490.photobucket.com/albums/r...C/SAM_0969.jpg http://i490.photobucket.com/albums/r...0104011752.jpg simple and it works. here is a short test video. http://www.youtube.com/watch?v=VsysoxXmuUU |
I put together an onboard video. Here is a link to the thread. http://www.rccrawler.com/forum/showt...74#post2873774 |
