11-08-2010, 09:43 PM | #1 |
Newbie Join Date: Nov 2010 Location: Mckinney
| ax 10 4wheel steering help
I want to put 4ws on an ax10, ive ordered the kit and servo...what radio/reciever should i use to get all fuctionallity out of it such as independant controll for front/rear, crabwalk etc. DO i need anything else? My first crawler build so any help is appreciated
11-08-2010, 09:53 PM | #2 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
First, read this thread. Frogger's BAD COP twin! Now, in short, here is what I used. Spektrum DX3R radio Spektrum SR300 RX PunkRC 4 steer switch dual HS-7954SH servos Castle Creations BEC HH Torquemaster BR-XL ESC HH Torquemaster 45T handwound motor That will get you started. The PunkRC 4 steer switch is badass! I use a 3 position button on the TX to switch between different modes on the 4 steer switch. Mode 1 = 4 wheel steer. Mode 2 = 2 wheel steer. Mode 3 = crab walk. Have fun. Casey |
11-08-2010, 10:21 PM | #3 |
thanks for the suggestions. You rock |
11-08-2010, 10:27 PM | #4 |
Keep in mind, this setup with 4 wheel steer will not be allowed to compete in any class...except, if you keep your 4 steer switch locked at 2 wheel steer mode. Then you can compete in the sportsman class. But, I did not build this to compete with...just for fun...and it is fun! Casey |
11-09-2010, 07:53 PM | #5 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
I am not sure about this, because I have never built a rig with 4w steering. I wanted to build a comp rig, but I am pretty sure you can get a Futaba 3PM-X and your done. It has 4w steer mixing.
11-09-2010, 07:56 PM | #6 | |
This is correct...and cheaper. With the 3PM-X, you will not need the PunkRC 4 steer switch. I was meerly showing my setup. Casey | |
