11-09-2010, 11:55 AM | #1 |
Rock Stacker Join Date: Jun 2006 Location: sanatoga
| i need help.
i am not sure if this is the best way to build my rc so i figured i would ask. basically what i want is a scx10 with rear steer and 2.2s. i was going to order a ARTR ax10 , tcs scale trail x chassis , 5 channel radio and the rest of the parts needed to make the ax10 rear steer. i was going 5 channel because i want to steer front and rear seperate plus winch and lights. my thought for odereing the ax10 and not the scx10 was the ax10 comes with parts for rear steer (i believe) and it already has the 2.2 tires and wheels. i know i will still need a motor and a body which i would end up changing if i got the scx10 anyway...
11-09-2010, 07:46 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
The ARTC does not come with parts for rear steer. No one runs rear steer on an AX-10 since it is designed to be a comp rig and rear steering is not legal for competion. I would probably just order the SCX-10 if I were planning to build a scaler.
11-09-2010, 07:55 PM | #3 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
if you want to do this, start with the SCX10. Then upgrade a few things. The stock wheels and tires with any kit really suck...so, you will upgrade them anyway. If you want info on a rear steer rig...check mine out. Frogger's BAD COP twin! |
