11-11-2010, 09:13 PM | #1 |
Quarry Creeper Join Date: Jul 2010 Location: Gila & Cibola
| 4 link up front
On a front axle 4 link setup, do you guys run your links above the mount, below the mount or one over & one under? (mount=servo plate) thanks |
11-11-2010, 09:29 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
Im using one of these, it puts the links side by side. When I ran mine on a plate they seemed to bind the front end. http://www.neweramodels.com/item.cgi...=&part_id=8983 |
11-11-2010, 09:54 PM | #3 |
Quarry Creeper Join Date: Nov 2010 Location: Toronto Canada
I just started putting my truck together and I'm running the TCS 4 link servo mount, I tried first mounting the links on the top but the end links were binding or hitting the plate. I switched to the bottom and have no problems, someone else suggested to me to check out the d-mount. Sorry I double checked and the d-mount is only for the rear. |
11-11-2010, 10:12 PM | #4 | |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
11-11-2010, 11:00 PM | #5 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Pretty much depends on how much vertical separation your chassis has between the upper and lower links. I've built rigs with links above and below the plate, and both have worked well. Both setups will also depend on how much room you have for shocks, steering, battery/servo, preventing binding, etc.
