Thread: Rollback
Old 11-14-2010, 01:52 AM   #1
Default Rollback
Hi there.
i've a noob question.
Can someone explain me why the rig rolls back when u go uphill?
I've got ax10 rtc 1 week ago. Once it was totally stock, nothing was noticed like that. But since i added some weight to the rig and wheels, it started to roll back, when u stoped during the uphill (i do not pull the trigger to brake).
Does that mean the motor is not so powerfull to hold it or?
shizzz is offline   Reply With Quote
Old 11-14-2010, 02:04 AM   #2
The stock esc doesn't have a drag brake. The motor itself will hold it a little bit, but like you noticed, when you add more weight it won't be able to hold it. There are several different esc's that have a programmable drag brake, like a Holmes Hobbies torquemaster br-xl, or a Tekin fxr.
Slowkrawl is offline   Reply With Quote
Old 11-14-2010, 02:21 AM   #3
Thnx a lot.
So the new esc will fix the bug.
I really like tekin stuff but....
is there any cheaper alternative? is there any sense to buy a used one?
At least for now, i'm not planning to invest too much in electronics.
The first step is mechanical part, the second is electronical, but as i see all the things are to close to each other and once u start upgrading in easy and cheap way u have to understand it will affect the other changes
Old 11-14-2010, 02:30 AM   #4
Originally Posted by shizzz View Post
Thnx a lot.
Personally I would run the stock stuff untill it dies, which knowing axial electronics won't be long. Don't fix it if it's not broken!
Old 11-14-2010, 02:39 AM   #5
Those were my intensions,
but since i live in that hole, i have tothink in advance.
We don't have too much choice here, u know
I would only change the esc + radio in future.
Now the links and a skid plate are on their way.
The rest will be in use until the complete destuction
I like the motor, i like the set in general, but for some plastic stuff and loosen screws which i already have substituted.
Old 11-15-2010, 05:33 PM   #6
When I got mine I spent my money on upgrading all the stock plastic steering components and got a better chassis. I didn't get my tekin till much later, but I would highly recommend the FXR. Before you spend too much on links and skids I would get a good chassis. All the good ones come with a skid and either come with links or you can make your own out of delrin.
Aggie01 is offline   Reply With Quote
Old 11-15-2010, 06:55 PM   #7
You can get a Novak rooster crawler esc for $60 for a remanufactured one on Novaks site.
out4crawlin is offline   Reply With Quote
