11-14-2010, 09:46 AM | #1 |
Newbie Join Date: Oct 2010 Location: dfw
| Shocks
what are the best shocks for my axial ax10. it has a dig function in it. i want to upgrade my shocks but dont want to spend 100$ on shocks. i bought the crawler for 250 with a bunch of upgrades and a spektrum radio and reciever. please help!!!!! i will just be doing general rock crawling. no competition.
11-14-2010, 09:52 AM | #2 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
I cant answer what the other guys say but i tinkered with my stock shocks using oil and different spring rates and it does very well. If you dont have the cash flow, mess with the springs and shock oil its a 15 dollar upgrade lol
11-14-2010, 09:53 AM | #3 |
Pebble Pounder Join Date: Feb 2009 Location: WV
From what I have seen so far on the subject it seems the top three recommended shocks in no particular order are the Traxxas Big Bores, Losi Leakers, and the Axial Comps. You should be able to pick any of those up for $60 a set or less.
11-14-2010, 09:57 AM | #4 |
11-14-2010, 10:11 AM | #5 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
I'm using EVADER rear alum threaded shocks in all 4 corners with rod end mod. Measure at 4 1/4" hole to hole after the mod. They perform just like my other losis but got them dirt cheap. |
11-14-2010, 10:14 AM | #6 |
| Tho that may have work and may still be working. Adding weight to ur wheels and pushing extreme flex is going to pop the stock shock cap right off. That was the first thing to blow out on my ARTR way back when. |
11-14-2010, 10:21 AM | #7 |
| shocks
what about the integy shocks? are they any good?
11-14-2010, 11:50 AM | #8 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
11-14-2010, 12:32 PM | #9 |
Rock Crawler Join Date: Aug 2009 Location: milton,wv
i went with the axial aluminum shock bodys and tried the different shock springs and they work really well
11-14-2010, 12:39 PM | #10 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
e maxx shocks http://cgi.ebay.com/NEW-3-3-T-MAXX-S...#ht_500wt_1156 losi white springs http://cgi.ebay.com/Losi-XXX-2-75-Wh...#ht_2901wt_905 search for the shock cap mod...do that and you are set i have been running this setup since i started crawling and it works... great cheap shocks that dont leak |
11-14-2010, 02:26 PM | #11 | |
Quarry Creeper Join Date: Sep 2009 Location: Abbotsford BC
X2 on the big bores! I run my 3.5" BB's with a rod end mod and MRC springs... work flawlessly and no leakage at all! plus you can buy a pack of 8 for $60 | |
11-14-2010, 09:34 PM | #12 |
| Shocks
So if I get the traxxas big bores what kind of "rod mod" would I need to do? And what springs would I buy? I'm really new to this. Please help!!!!
11-14-2010, 09:41 PM | #13 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
Get a set of Losi Crawler shocks, run 30w oil in the front with Gold springs and 50w oil in the rear with yellow springs.....all shocks are going to leak if you use them enough, if your shocks are not leaking your not working them hard enough.
11-14-2010, 09:55 PM | #14 |
I have these aluminum shocks the guy gave gave me and installed those. The problem is they are really long and leak overnight. I don't think that's normal.
