11-21-2010, 02:09 PM | #21 |
Rock Stacker Join Date: Oct 2010 Location: SLC
so this is what me and my buddy came up with . took a piece of delrin plate and cut a link out of it, shaved the front side to a 45 ish degree angle and then drilled a hole for the servo linkage to connect to the steering link. so i got rid of the double stacked ball joints no rubbing, i can see those stock rims might not make it back on the rig again, the DNA have a little more spacing. these are the skinny tires so it looks better, but when the sedonas/rovers are on its going to be alot closer. might still get a wider hex nut just in case. thanks again. Last edited by bubbaskyjacker; 11-21-2010 at 02:11 PM. |
11-21-2010, 03:13 PM | #22 | |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
That said, it looks like you've found a pretty nice solution to your problem. Nicely done. You'll find in this niche of the hobby that you're required to do more custom fab than most any other type of RC. | |
11-21-2010, 09:38 PM | #23 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Glad to see you kept them. Nice job on the tie rod |
11-21-2010, 09:53 PM | #24 |
Rock Crawler Join Date: Nov 2008 Location: Roseville,Ca
Nice work on the tierod setup glad to see you got it figured out. |
11-22-2010, 02:05 AM | #25 |
Quarry Creeper Join Date: Oct 2010 Location: SLc,UT
And you said the delrin I have is not the right kind.... Next time we need to counter sink the tie rod a little so the nut/bolt wont stick out the bottom.
11-22-2010, 04:26 AM | #26 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
looks good |
12-08-2010, 11:44 AM | #27 |
Newbie Join Date: Jan 2010 Location: phoenix
X2 glad to see you figured it out, looks good got any updates ? |
