11-25-2010, 07:03 PM | #1 |
Newbie Join Date: Nov 2010 Location: Folsom
| Is this too much juice??
I have a new stock motor (Novak 55 turn) currently running 2s lipo, but thinking about using 3s lipo (following specs) from my Rally xlt - is it too much juice? It's the Venom Li-Power Series 3S 1P 11.1V 1300mAh SPECS: Length: 3.54" (90mm) Width: 1.34" (34mm) Height: .71" (18mm) Weight: 4.6oz (130.4g) Charge Rate: 1.3A (1C) Max Volts Per Cell: 4.2V Max Pack Voltage: 12.6V Min Discharge Volts: 8.25V Continuous Discharge: 20C (26A) Max Burst Rate: 30C (39A) http://www.rcboca.com/venom-racing-2...ttery-trx.html Last edited by RCchomp; 11-25-2010 at 07:38 PM. |
11-25-2010, 07:32 PM | #2 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
Its not really the motor you need to worry about. Can your ESC handle it?
11-25-2010, 07:38 PM | #3 |
11-25-2010, 07:40 PM | #4 |
Rock Stacker Join Date: Aug 2010 Location: Winnipeg
Post a picture of the esc or figure out what type it is because your question can't be answered without knowing that.......
11-25-2010, 07:40 PM | #5 |
Not for the motor. Alot of guys run 4s. You need to find out what ESC it is first.
11-25-2010, 07:54 PM | #6 |
| It's a "Rooster Crawler" - purple. The UPC says 22G35856.
11-25-2010, 08:00 PM | #7 |
11-25-2010, 08:21 PM | #8 |
| Sorry for all the questions (not new to RCs but new to crawling). What are the side effects of the TorqueMaster BR-XL. It says it can handle 3s to 6s but will I need to replace the Novak 55? If the Novak can handle it, will break other things? I'm assuming it will add speed but will that reduce the ability to crawl at slow speeds?
11-25-2010, 08:23 PM | #9 |
Rock Stacker Join Date: Mar 2010 Location: washington
11-25-2010, 08:24 PM | #10 | |
11-25-2010, 08:26 PM | #11 | |
11-25-2010, 11:42 PM | #12 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
I ran 3S on a rooster crawler edition for more than a year. The biggest problem is that the internal battery elimination circuitry cannot handle the load of the motor and servo at the same time. You won't be able to steer while on the throttle, and it does not have the proper cutoff voltage. With a Castle BEC, and a cutoff or monitor for voltage, you will be just fine with a 55T. I run a Holmes 40T and BRXL now in the Axial rig, but my 55T with a CE worked just fine. The ESC is still running after about 2 years now in a buddie's rig. |
