Thread: bearings question
Old 12-06-2010, 03:57 PM   #1
Default bearings question
For both axles you will need :
Eight 10x15x4mm
Eight 5x11x4mm
For the Tranny :
Four 5x10x4mm
Two 8x16x5mm
is this correct for a complete bearing replacement in an ax-10?
I have a gift certificate for avid and need to know which ones I need of what type? (metal, rubber or revolution)
mudn_1 is offline   Reply With Quote
Old 12-06-2010, 08:22 PM   #2
I don't have my parts list handy, but that sounds about right. I've been using rubber-sealed bearings on my rig with no problems.
version_three is offline   Reply With Quote
Old 12-06-2010, 08:38 PM   #3
I run Revolutions in both my Comp rig and my Scaler and really like them. Every bearing I've purchased thus far has been smooth, consistent and they've held up beautifully.
Avid will have my business as long as I'm in the hobby.
CreepyCrawl is offline   Reply With Quote
Old 12-06-2010, 09:10 PM   #4
sounds good I am excited to try them, just didnt know which ones exactly.... if someone gets a chance, let me know if those are right
Old 12-07-2010, 08:32 AM   #5
Straight from the original AX10 manual...
5x10x4: 4 Total
5x11x4: 12 Total
8x16x5: 2 Total
10x15x4: 8 Total
If you use a Straight Axle conversion in the rear you'll eliminate 2 of the 5x11 bearings.
I always order one extra of each size; price is right
Old 12-07-2010, 09:58 AM   #6
My local hobby shop carries every bearing needed for Traxxas vehicles. The 5x11x4 is very common, so is the 10x15x4. I had these bearing for my Slash 4x4. the Traxxas bearings hold up just perfect in my AX10.
Im sure some of the other Traxxas vehicles could use the 5x10x4 and the 8x15x5.
Just offering up a suggestion for anyone in a bind and not wanting to order bearings.
madkawi650 is offline   Reply With Quote
