Thread: Free to Cheap COG and Driveshaft mods
Old 11-29-2010, 04:09 PM   #1
Default Free to Cheap COG and Driveshaft mods
Anyone have any free to cheap mods I can do to lower my COG and fix my drive-shaft? My front drive-shaft hangs below the links and catches on stuff when I go over them. I have both the front and rear 4 linked too.
Over-all shot.
As you see on the left side, the drive-shaft hangs down under the links, it doesn't look so bad in the pic, but it makes a terrible difference!!!
armycrawler101st is offline   Reply With Quote
Old 11-29-2010, 04:29 PM   #2
Have you tried using the straight lower links in front? Maybe flipping the bent ones backwards would match the driveline angle better?
Could make a custom diff/pinion skid plate.
GRIMGREG is offline   Reply With Quote
Old 11-29-2010, 04:37 PM   #3
Suck it up!
Duuuuuuuude's Avatar
Read the stickies at the top of the page...there is lots to learn there.
Duuuuuuuude is offline   Reply With Quote
Old 11-29-2010, 04:44 PM   #4
Keep it real
Tanis's Avatar
I wouldn't sweat it, I roll my front pinion down to gain caster, driveshaft rubs the rocks, never got stuck from it
Since the driveshaft is spinning, it's pretty tough to get hung up by it.
Tanis is offline   Reply With Quote
Old 11-29-2010, 04:48 PM   #5
X2 on straight links up front, and what Tanis said... That MIP is metal, BEAT ON IT!
dickwart is offline   Reply With Quote
Old 11-29-2010, 05:10 PM   #6
What about my COG? I seem to roll over easily lol
Old 11-29-2010, 05:11 PM   #7
Out board your shocks on the chassis and the axle...
Old 11-29-2010, 05:32 PM   #8
i run straight links on my tigress and never have troubles on the rocks.......bob
bob1961 is offline   Reply With Quote
Old 11-29-2010, 05:55 PM   #9
Default cog
Move the bat down to the front ax.you will have to run sad packs or a lipo .I run a 2 or 3 s ont the frount axel and it helps
wurster is offline   Reply With Quote
Old 11-29-2010, 05:55 PM   #10
Try to Bend it
Highlucks's Avatar
Looks like you are still running your battery on the stock battery plate. Get yourself a cheap saddle pack or lipo so that you can mount it on the front axle. Also limit your shock travel so that you only have around 5-6" of articulation with the other 3 tyres resting on the ground.
HTH.
Highlucks is offline   Reply With Quote
Old 11-29-2010, 05:57 PM   #11
Chris_The_Battery_Man's Avatar
Your link geometry and shocks are probably alot to do with you rolling. The stock chassis, links, and shocks limit performance. I would recommend the GC3A chassis and Traxxas big bore shocks for ultimate performance. I know that is not "Cheap or Free" but worth the $$ for sure
What are you running for a battery, charger, and ESC?
Chris_The_Battery_Man is offline   Reply With Quote
Old 11-29-2010, 06:08 PM   #12
I'm still using a nimh but already plan to change, and i'm using a sidewinder 1/10th for esc
Old 11-29-2010, 06:25 PM   #13
I would consider using a small lipo then, and you will be much happier
Old 11-29-2010, 09:08 PM   #14
If you lengthen your front upper links, that will clock your axles and move your drive shaft up out of the way. You will want to get a better chassis some time, but that is a cheap - free fix for your problem for now. I would hold out for the T1E chassis coming out for the AX-10.
You can experiment with adding different sizes of spacers between your rod ends and the link rods. You want the pinion to point upwards towards the tranny. This also staightens out your drive shaft, which puts less strain on it.
Aggie01 is offline   Reply With Quote
Old 11-29-2010, 09:11 PM   #15
Suck it up!
And if you do that without having clockable c's, it'll throw your caster way out of whack.
Old 11-29-2010, 09:31 PM   #16
Keep it real
Tanis's Avatar
Yep, and steering into the ground mostly
Old 11-29-2010, 09:51 PM   #17
If you have some soldering skills and some wire laying around reconfigure your battey like this.It makes a huge diferance, and can be free if you have the stuff to do it.
Cave Dave is offline   Reply With Quote
Old 11-29-2010, 09:52 PM   #18
They are right, but you asked for free to cheap. Clockable C's will run you about 30 bucks. Or you can get some beef toobs, which will allow you to clock your stock C's with a little dremel work on your axle housings.
Old 11-30-2010, 07:57 AM   #19
I don't know about RC that well as I'm new to it, but I know some 1:1 Crawlers have actually used the driveshaft spin to slide them sideways across the rocks until they can grab a tire if they are hung up on it.
Old 11-30-2010, 08:10 AM   #20
add some weight to the front.
relocate and reassemble ur batt or buy a lipo and place it in front. on the right side.
shizzz is offline   Reply With Quote
