Thread: Slipper Questions
Old 08-28-2010, 03:53 PM   #1
Default Slipper Questions
I am going to upgrade my internal gears shortly on my AX10 comp rig and not sure how to get the Axial tranny to run w/o a slipper. Do you just take off the slipper pad and tighten the nut all the way down w/o the spring?
Also for those of you running a slipper how tight do you set it? I have mine screwed all the way in and loosened about a quarter turn.
alexchen86 is offline   Reply With Quote
Old 08-29-2010, 12:49 AM   #2
i have my slipper set almost full loose and it still barley slips...maybe mines special lol
axial 888 rtc is offline   Reply With Quote
Old 08-29-2010, 11:57 AM   #3
I run mine fairly loose. step on the back tires, and hit the gas. front end barley lifts. If you have any plastic parts to tight on the slipper will twist/bend em. You want enough torque getting through to crawl, but also want to protect the parts. If you really don't want a clutch in it, a little CA on the slipper disk will lock it solid.
JohnDoeGeneric is offline   Reply With Quote
Old 08-29-2010, 07:54 PM   #4
if you rebuild your tranny without the slipper you will need the shorter top shaft...
axial part# AX30197
roksloski is offline   Reply With Quote
Old 08-29-2010, 08:12 PM   #5
If I tighten the slipper all the way in and use CA on the slipper pad won't that be the same as having no slipper?
Old 08-29-2010, 08:20 PM   #6
Tossin' Salad
axial part# AX30197
Thanks for that.
Casey
KC_JoNeS is offline   Reply With Quote
Old 10-10-2010, 09:19 PM   #7
Default tonights mod
So I was having problems with my slipper constantly loosening up and slipping when the bind I was in was not even that bad. So I did a mod tonight. I drilled out the back plate (the tranny side) of teh slipper assembly. I then used a longer 3 mil screw though the spur gear. Anyway the 3 mil went all the way though and I now have no slipper without the hassle of ordering all these new parts.
RickM is offline   Reply With Quote
Old 12-03-2010, 10:37 PM   #8
I like the free slipper mod. Thanks Rick
Aggie01 is offline   Reply With Quote
Old 12-04-2010, 06:20 AM   #9
Hey, glad to help you not spend money on some things when we know we all spend to much on this crazy hobby anyway.
Old 12-05-2010, 10:06 PM   #10
Default can you post apic of the mod
that is a solid mod, would you mind sharing a pic?
nutoscaln is offline   Reply With Quote
