01-11-2011, 05:15 PM | #41 |
Quarry Creeper Join Date: Oct 2010 Location: So. Cal
01-11-2011, 07:29 PM | #42 |
01-11-2011, 11:28 PM | #43 |
01-12-2011, 02:27 PM | #44 |
01-13-2011, 01:34 PM | #45 |
01-13-2011, 07:34 PM | #46 |
Alright gentlemen, we have cut-age! Went the cheap and easy way. I bought a cut-off wheel and mandrel, and chucked it up in the 'ol drill should be able to run most gear combos now. May have to shave the trans a lil bit if I need to, but I will hold off on that for now. |
01-13-2011, 07:39 PM | #47 |
Also did a bit of experimenting with my electronic mounting. right now I have the receiver mounted upside down on the upper braces. (also mounted the dig servo) Can't decide if I should mount the batt. to the front link tray Or should I get a longer servo mount and run the batt. there and put the esc on the tray? Another option would be, battery on a rear link tray, and esc on the front. Thoughts? |
01-13-2011, 07:49 PM | #48 |
oops...double post
01-26-2011, 04:58 PM | #49 |
Not much progress lately but I did do the 3 position toggle mod to my controller today Now I just gotta wire up the rest of my electronics so I can test out and make sure it works. Last edited by Sniper4370; 01-26-2011 at 05:05 PM. |
01-26-2011, 06:38 PM | #50 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Hmmm I see some un-used mounting holes on the front servo plate. Thought of making a mount that screws on there and then running a tab between the middle links to hold the electronics or battery. Sorta like what the T1E shafty chassis does. I love the creativity with zip ties and trying new electronics positions, sure can make a huge difference |
01-26-2011, 09:05 PM | #51 |
What weighs more, the battery or the esc? Put the heaviest on the front links, the lightest on the rear links. Better yet, make or buy a battery/servo mount for the front axle. |
01-27-2011, 01:37 AM | #52 |
| This is what I think I'm going to do. BTW, any idea how I can get my hands on a D-mount? |
01-27-2011, 04:19 AM | #53 |
Pebble Pounder Join Date: Nov 2007 Location: Alice Springs/Australia
This is what I think I'm going to do. BTW, any idea how I can get my hands on a D-mount? You could make one they would be very easy to make!! Last edited by mint355; 01-27-2011 at 04:24 AM. |
01-27-2011, 03:48 PM | #54 |
01-27-2011, 05:43 PM | #55 |
Hey Sniper I know you made your cut but if you want more room ditch the slipper clutch and you could cut a bit more off for easier maintenance. |
01-27-2011, 05:53 PM | #56 |
^^^ x2.
01-27-2011, 09:22 PM | #57 |
Yeah once I get it running and start messing with gearing I may just need to do that. At least at this point I have the motor mounted up and have a better Idea where I'm at for clearances. Thanks guys.
01-28-2011, 06:08 PM | #58 |
Well....after a call to Castle, and having to hook up my old Win.XP machine, I got my MM programed. Then I went on to try setting up my dig servo, what a bust! Can't seem to get the epa's right. Really getting frustrated. Either I wired the toggle wrong, or my controller is just not going to work with the dig. I think I'll go shoot faces on BF:BC2 for a bit and come back to this later. |
01-30-2011, 02:31 PM | #59 |
I'm thinking about ditching the dig. Or, just disconnect it and lock it in place, seems to be more hassle for me than it's worth. Also, I need to stay out of the scale section. I don't even have this pig running yet, and I want a damn scaler now |
