12-04-2010, 02:41 PM | #1 |
Quarry Creeper Join Date: Jul 2010 Location: Gila & Cibola
| Sixteen Horsepower's AX-8 Buggy Update on page 3. Skip all this boring stuff. The spirit of this build is just to see if i can stretch my Scorpion to a 16" WB and run a tall, skinny tire/wheel at low speed and still crawl worth half a damn. Maybe it's just a natural progression towards wanting to build a super. Main thing is that tinkering and this site are a lot of fun. i'll throw up pics as i can, but wanted to start by saying thanks to RCCrawler, Axial, TCS, RPP, Vanquish, Traxxas, RCBros, McMaster-Carr, Proline, RC4WD, Wantasummit, Hobby Proz (Albuquerque) and others as i think of 'em. i guess i'll start with the tires and wheels and then post up as i can. The more comments or ?'s the better. Thanks i started with this. Changed it to this. And even messed around with some proline 17mm hubs for these 3.2's. It was fun for a day, but would snap stub axle pins. Wanted to try these. Low budget way to make a 24mm wheel fit a 23mm hub. Gotta get back to work, will post some more later. Last edited by 16hp; 09-29-2011 at 07:41 AM. Reason: update |
12-04-2010, 08:43 PM | #2 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
interesting. I really like that wheel tire comb it looks bad a$$
12-05-2010, 08:42 AM | #3 |
The stock 12mm aluminum hexes are nice, but the raised part on the outside did not fit jamb-up inside the RC4WD adapters. i was going to just file them down, but found these at TCS. They are narrow, flat and serrated. i was using the AS-2 servo for the VP dig, which worked just fine, but while it was apart, i put in a mini bracket,Hitec 225 and Losi 13t pinon. i have a Robinson 90t spur if i need it, but don't know if it even fits next to the drive shaft yoke. |
12-05-2010, 09:02 AM | #4 |
This is the material i got from McMaster-Carr and decided to try the 1/2" PVC rod for the lower links. i had'nt seen PVC used before and gave it a shot. It cut, tapped and bent just fine. |
12-05-2010, 09:07 AM | #5 |
After a lot of reading on this site, i used Revo ends and 8/32 set screws from RCbros. My chamfering job kind-a sucks. i just used a disc sander. |
12-05-2010, 09:08 AM | #6 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
really cool, should be interesting, I can't wait to see it with those wheels and tires mounted, good work so far!
12-05-2010, 10:20 AM | #7 |
Forgot to mention the upper links are 5/16 delrin from RCbros. i can already see a possible need for some Beef Toobs and AL c's. i bought an RC4WD punisher shaft from TCS, but turned out it was just a stock length. http://www.tcscrawlers.com/images/P/...ft_ax10_pi.jpg i kind of wanted to do a maxx shaft conversion, but for now i just robbed the stock shafts of of my Honcho and made these. i can use the punisher shaft on the honcho. i need to use it to halfway justify the cost...jeez. |
12-05-2010, 10:25 AM | #8 |
| Thanks fred. i always spend too much time "contiplating" your avatar. i searched and read a lot on the superclass and large scale board and would love to try a cut and shut someday, but came across these Baja front wheels and Bowtie's. They are just the size i was looking for. They will probably need some modding, like remove the foams completely or star cut them like crazy. Or just leave'em, what the hay.
12-05-2010, 12:18 PM | #9 |
You're going to destroy that driveshaft the first time you even think about putting it in a bind. At the very lease you should get some Traxxas shafts/Axial rings...personally I'd look into Maxx shafts. Easy to do and much stronger.
12-05-2010, 12:28 PM | #10 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
If you put 8-32 all thread through the male part of the drive shaft it will resist twisting. Drive shaft rings are going to be a must.
12-05-2010, 01:14 PM | #11 | ||
This is great, thanks for the feedback. On to the dampers. i could more or less make the front dampers work with link mounts drilled out to fit onto a Revo end (i think it was like a 9/32 bit), but the rear needed a chassis extension. i was kind of wanting a chassy forward and the skid angled down, like i had seen on the super board, and when i put it together, that's how it sat. i was suprised. This is my fav. pic so far. | ||
12-05-2010, 01:32 PM | #12 |
Yes, the shafts fit on the Axial yokes. 1951 is the # IIRC... The Maxx yokes just barely clear a 87t spur. Mine had a slight wobble and there was some interferance, but after several runs the spur cut a groove in the yoke and all was well. Old style Tmaxx yokes were 5mm, all the new ones are 6mm. Either way it doesn't matter too much, you'll want to drill them out to hold the Axial yoke. If you haven't read the "maxx shafts made easy" thread, find it and do so. Also, those rear extensions are going to fold over on the first good hit. I tried using similar material on my super...didn't work well. |
12-05-2010, 06:08 PM | #13 |
Oh i'm sure shits gonna break and bend. When it does, i'll read some more and make it MO'BETTA! |
12-05-2010, 08:22 PM | #14 |
12-05-2010, 08:33 PM | #15 |
That actually looks pretty badass. If I were you, I'd be getting some aluminum C's and knuckles ASAP. |
12-05-2010, 08:38 PM | #16 |
With original body. i'm gonna use this body for now-electronics already inside. i might remove the stinger and some of the front part of this body right above the servo and battery. Not sure yet. Still needs a shakedown run. Thanks for look'in. i'll post some poser pics later. |
12-05-2010, 08:45 PM | #17 |
12-05-2010, 08:49 PM | #18 |
Picture flipped now. Next to my Honcho. |
12-05-2010, 08:50 PM | #19 |
It'll be interesting to see how those low profile tires do. You've got the foams in them I assume...
12-05-2010, 08:53 PM | #20 |
