12-16-2010, 05:21 PM | #21 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
No rainbow colors, but it sure looks ghey! |
12-17-2010, 11:03 PM | #22 |
I like it Tom, And I look forward to seeing it run the next time I'm down there |
01-01-2011, 11:24 PM | #23 | |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
Are you going to make it to the comp tomorrow? Maaaybe the ORCRC comp next Sunday? Anyways, I'm getting a lot of odds and ends done tonight on the GC-3A! Starting with some motivation! More updates as they come! TOM | |
01-01-2011, 11:31 PM | #24 |
Gotta thank Zippy for the Monster stickers They matched really well. And it's even the girlfriends favorite energy drink! I just had to put the "trucker chicks" on it! Since this is a girls truck after all... Last edited by sourdojack; 01-02-2011 at 12:02 AM. |
01-02-2011, 12:09 AM | #25 |
Here are some pics of the body on the truck. I cut it too short before I mounted it. I originally thought I could slam the body lower, but without doing a "trick" steering set-up, this is as low as I can go. I don't think I can do the Gatekeeper style steering with the pinion angle/caster angles I run anyways. The last time I drove the truck the front didn't seem to flex well. So before I soften up the springs, I'm going to raise the shocks on the axle. This in boards them 1/4" and lays the angle down flatter. We'll see how it dirves tomorrow at the comp. |
01-02-2011, 01:07 AM | #26 |
Here are pics of my little dig. I used some polishing cloth on the case to keep the shifter sliding smoothly. And of course for the bling factor Here is the top view of how I routed the wiring. I used some 1/4" Delrin rod to hold the servo in place at the chassis. The lower piece has all thread through the center clamping the servo in place. I coated it in CA glue after I got it all installed to keep it from moving at all. It's just a temparary mount out of delrin since I broke my 3mm tap Still has a nice and low COG though Here is the final weight with Cheapbatterypacks.com 850mah 3S lipo |
01-02-2011, 01:17 AM | #27 |
For you guys wondering about my wheel weight. Front wheel/tire combos are 10.0 oz each and rears are 6.5 oz each. So 7 oz of weight added to the front wheels. Here is the total weight bias! Front axle is 3 lbs 1.1 oz Rear axle is 2 lbs 0.7 oz So right about a 60% front weight bias... Dunno if that's good, but the truck sure drives great so far! TOM |
01-02-2011, 02:37 AM | #28 |
Rock Crawler Join Date: Sep 2008 Location: estacada
i want that much caster |
01-02-2011, 06:51 PM | #29 |
Rock Stacker Join Date: Oct 2007 Location: On the edge of sanity...
| Nice build!
Sweet rig, and the motivation is mutual... thanks for the weight specs!
01-02-2011, 10:14 PM | #30 |
wow i drove this thing today, holy shit by far one of the most capable shafties i have ever seen or drivin |
01-02-2011, 10:25 PM | #31 |
Pebble Pounder Join Date: Jul 2009 Location: Woodburn
It'll never work... xoxo |
01-03-2011, 01:38 PM | #32 |
Here is a quick vid of Josh driving it up a line I have never made with a no-dig shafty before. One of these days maybe Chris the Battery Guy will come make some sweet video's of the new build. I just need to "cup the balls" better i think... lol http://www.youtube.com/watch?v=QLAF6fI1hK0 Last edited by sourdojack; 01-03-2011 at 01:43 PM. |
01-03-2011, 09:27 PM | #33 |
Ah yes, I recognize that line, nice work Josh You mean to tell me the sun shines down there in the winter.....apparently only when I'm not down there |
01-05-2011, 01:24 AM | #34 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
01-05-2011, 05:33 AM | #35 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Rig looks great. Is it because of the toobs your able to get the castor u have? |
01-05-2011, 08:39 AM | #36 | |
01-05-2011, 08:43 AM | #37 | |
Here are some old pics of rotating my axle C's TOM | |
01-05-2011, 11:04 AM | #38 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
Hey SDJ, You've got a very clean build. Eritex dig looks tiny. I really debated between this set up and the VP dig. How do you like it?
01-05-2011, 11:47 PM | #39 | |
TOM | |
01-05-2011, 11:58 PM | #40 |
I made it out to my buddys machine shop tonight to lighten up my Robinson spool. Here are some pics! Disregard the marks on the gear from when I tried to drill it We used a 1/4" carbide end mill, only thing I could find that would cut through the surface hardening. Now when the girlfriend strips out the stock trans gears she can install the steel gears TOM |
