Thread: Sourdough GC-3A
Old 01-06-2011, 01:24 AM   #41
Chris_The_Battery_Man's Avatar
Looks good for a homo
I may have to come out and test it for ya soon. May not make it to the next ORCRC to Vid/pic because of rain, but I want to come drive this on something but the steps in Jasons garage.
I still think you should bite the bullet, and get a holmes motor and 4S. You will NOT be dis-appointed. I LOVED mine in the XR. So buttery smooth. Ask JonB. He can tell you how smooth
I almost got that line too with no dig. Looks like it was drier than when I tried it. Plus, you have over/under drive. Fag
Chris_The_Battery_Man is offline   Reply With Quote
Old 01-06-2011, 10:54 AM   #42
I was to see if Holmes will re-wind my 500 puller with that new "double duplex" wind. Wanna give him a call for me? He doesn't take PM's... lol
But yeah, I love the can size of my motor and I would hate to jump to a full size can. If I can get my motor slowed down a bit with better low end control, I would much rather spend $50 on that...
Weather looks decent for this weekend. You should carpool with Jason or something
TOM
sourdojack is offline   Reply With Quote
Old 01-06-2011, 11:01 AM   #43
Well work was slow this morning, and I kept staring and my Robinson spool and finally I chucked it up in the drill press.
About an hour of die grinding, filing and sanding, I got this as an end result!
Not too bad for just eyeballing the whole thing!
Oh, and if anyone wants to try to drill one of these out, they are just surface hardened. So if you take a die grinder and narrow the gear first, you can drill through the side of the gear afterwards with a normal irwin uni-bit.
TOM
Old 01-06-2011, 06:07 PM   #44
Even though that gear looks like a pile of naked dudes, it's pretty cool.
Old 01-06-2011, 06:58 PM   #45
So I weighed the gear tonight at Tammies Hobbies, it tipped the scale at 23 grams. The stock Robinson Racing spool is 46 grams. So I cut the weight in half! Not bad!
TOM
Old 01-10-2011, 12:50 PM   #46
I would like to thank Jeremy for taking pics at the comp yesterday. Here is a pic he took of the girlfriends truck. She wasn't able to run the 4th course cause the FX-R got wet on the inside...
Old 01-10-2011, 01:12 PM   #47
Looks cool
goose ae is offline   Reply With Quote
Old 01-10-2011, 05:45 PM   #48
This truck really makes me want to make a no dig CG3 for funsies
Old 01-10-2011, 06:07 PM   #49
R.I.P. Chip
jason's Avatar
for funsies
jason is offline   Reply With Quote
Old 01-10-2011, 07:01 PM   #50
Who makes the shock relocators on the axle and vertical body mounts? Thanks
NMLJ is offline   Reply With Quote
Old 01-10-2011, 09:01 PM   #51
They're vanquish shock raisers.
Old 01-13-2011, 01:43 PM   #52
The body mounts are made by Gunnar
The Shock mounts are made by Vanquish Products
Old 01-13-2011, 01:46 PM   #53
Speaking of shocks, I was sick of my old Losi shocks leaking so off they went. Got traxxas big bore longs to replace them. With the rod end mod they are 4 1/8" long.
Old 01-13-2011, 01:56 PM   #54
So I was thinking about how I spaced my upper links to up my pinion angle to keep the driveline off the rocks. And this question came to mind; what should I change to increase my pinion angle.
Should I,
A) move the axle mounting point of the upper link towards the chassis?
B) lengthen the upper links?
C) move the chassis mointing point of the upper link towards the axle?
Which one is going to keep my suspension geometry in the correct GC-3 proportions?
I currently have option B, but I'm leaning towards option A.
TOM
Old 01-13-2011, 02:21 PM   #55
Keep it real
Tanis's Avatar
I'd say just lengthen your upper links, or not worry about it, your rear shaft looks like it's already up out of the way enough to me. And if it gets in the way, just pick better lines Tom
Tanis is offline   Reply With Quote
Old 01-17-2011, 04:44 PM   #56
I've got a question for you about your castor angle. I see you installed the beef toobs, to get that angle did you simply grind down the tabs at the top of the plastic axle housing and redrill to hole or is this simply your clockable c hubs? I'm thinking about getting the beef toobs myself and I really wanna lay the wheels back like you've done. Great build!
TC09mini is offline   Reply With Quote
Old 01-17-2011, 06:11 PM   #57
So to rotate the axle C's extra far,
First took an exacto knife and cut all the "tabs" off the edge of the axle tube.
Then I drilled an 1/8" hole further up on the end of the axle tube.
Then re-installed the C's (be sure to drill the hole in the axle C to 1/8") Then I rotated them back.
Then to keep the C's from rotating back down, I drilled and threaded a hole for a 3mm screw further in on the axle.
You can see the extra screws in this pic
TOM
Old 01-27-2011, 11:49 AM   #58
Natedog's Avatar
Nice build. What green springs are those on the BBs? What is the reasoining behind your front axle caster?
Old 01-27-2011, 01:00 PM   #59
This a a really nice build, looks good. I have to ask as I may have missed it, but what knuckles are you using?
Wicked Klown is offline   Reply With Quote
Old 01-27-2011, 04:11 PM   #60
The Green springs are from Losi for the Mini T Rear shocks. I have since switched to the Silver springs. Here is a link.
The large amount of caster helps keep the truck stable and it also helps turn uphill, not to mention add that extra 1/2" of reach when climbing a ledge.
After driving the crawler with gobs of caster, I won't go back
TOM
