01-03-2011, 10:49 AM | #21 | |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
The stock axle hexes need to be drilled out: 6mm on the bearing side, 5mm on the axle nut side. You also have to drill out the ring gear to 6mm/ 1/4" Last edited by gunnar; 01-03-2011 at 10:54 AM. | |
01-03-2011, 01:30 PM | #22 |
Rock Stacker Join Date: Oct 2010 Location: San Antonio
Ok so for the $150.00 I get the Locker, axle shaft, the cvd with the nut. And this will work on the Axial aluminium C-Hub, and Hi-clearance Knuckle?
01-03-2011, 01:37 PM | #23 |
01-03-2011, 03:14 PM | #24 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
01-03-2011, 06:33 PM | #25 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
